Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
MadMack
I don't care if this gizmo won't run 24/7 at 100% non stop. Nothing made by man will do that.
If it will run my household necessities for a day or two before it runs down that 1 battery, well that would be just fine with me.
Mack
Void
Quote from: Clarence on April 06, 2015, 11:08:04 AM
LOOK AGAIN!
this is the unit that was covered by the plastic in my previous post!
Clarence
Hi Clarence. OK, I see that Ariovaldo apparently did some tests with an actual B&L single transformer device.
I don't know why you couldn't have just said that. ;)
I will go back and read through Ariovaldo's posts here when I get a chance and review what he was able to
find out in his tests.
P.S. It looks like Ariovaldo could not get the device to work and came to the conclusion that the device was
most likely a scam? Ariovaldo, are you out there?
All the best...
Void
Quote from: MadMack on April 06, 2015, 11:50:47 AM
Hi MadMack. There are no confirmations so far that I have seen that it can do even that however.
All the best...
tinman
Mack
My clock on the wall runs 24/7 at 100%,and thats man made.
My wife's rocking dolphin toy runs 24/7 at 100%,and thats man made-->and it's been running on the same 9 volt battery for over 12 years-->24/7--->aint that a hoot ;)
In fact,it is quite easy to put together a system or device that will run 24/7 at 100%__>and one that wont cost you a cent to run-->a true free energy system/device. Lets say you want to run a water pump 24/7-->you give me the specs on the pump,and i will put together a device that will run that pump!free of charge! 24/7 at 100% capacity--> a real free energy device made from !off the shelf! parts ;)----->oh,and you wont need 50 ground rod's,just 1.
Clarence
Quote from: Void on April 06, 2015, 11:52:49 AM
All the best...
read and dig deep and you most probably will be shocked when you find out.
Clarence
