Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Enjoykin
Quote from: nelsonrochaa on April 06, 2015, 07:03:49 PM
Hi ,
Enjoykin i left my opinion about the spark gap subject , and the subject of toroidal transformer without the hv coil secondary.
The transformer toroid should have only the original primary in my case is 230v 50hz only the main primary.
about the "spark gap" :
Surge protector mechanism act like a pulse or spark gap. the effect can be achieved  with diodes too.
This discharge will do the work of pulsing .
See :
Primary coil generate a pulse of voltage higher then source , so the surge protector  discharge  to ground. but we have a small coil around the closed loop that go to ground in series with load . This will generate a reversed high voltage because secondary is  low turns so the induced voltage in primary will be very high, and the surge protector will discharge the excess again .
And the process will be repeat. but this is not a overunity is only a more efficiency process .
The closed loop is only to maintain the core of thyroidal transformer saturated. This is a MAG with feedback. Or saturable reactor with feedback.
Thanks
Hello nelsonrochaa !!  :D
Yes it have sence all what you have said - but i think spark-gap wiring is wrong in Ariovaldo schematic.
If you want you can try this SR193 old experiment with two toroidal transformers and HV sparks.
For maximum brightness HV spark should be fired exactly on top of positive half of sinusoide or on top of negative if you use negative HV source.
Both transformers are here because galvanic isolation from grid or sinus inverter. You can use LATR  - autotransformer in voltage ratio 1:1.
nelsonrochaa watch old experiments of Russian Persian Princess  :D
Эксперимент с 2 трансформаторами - (same configuration as SR193).
http://www.youtube.com/watch?v=dyDszwcuwlQ
Antigravity - It's easy - another experiment by Russian Persian Princess  :D
http://www.youtube.com/watch?v=-O_PkNv-pN8
Опыт 12 08 12
http://www.youtube.com/watch?v=7jtjgAwXqGg
SR193 Репликация.rar - Replication of HV sparking sinus
http://rusfolder.com/43399521
Her personal site
http://astralab.in/forum/index.php
Her channel
http://www.youtube.com/user/Hallavy/videos
tinman
Hoppy
Quote from: tinman on April 07, 2015, 06:08:38 AM
Well since were all throwing junk together-->here is the Tesla reactor. :D
https://www.youtube.com/watch?v=QVffZOnerUk
Nice junk yard project Tinman, complete with your unique brand of humour.  :) Given that you've labelled it as a Tesla reactor, as opposed to a normal reactor, now wait for the 'is it overunity' questions!  ;D
Hoppy
Quote from: a.king21 on April 06, 2015, 08:18:45 PM
I am interested in this thread from the point of view of current amplification.
ie current transformers.
If the Don Smith devices work with HV why not with HA  ie High amps.
Something that might be worth experimenting with. Take a MOT with re-wired secondary for high current (welding trafo style). Then step-up the very low voltage, very high current output, through a Tesla type transformer and charge up caps, to then pulse discharge into lamps. This is another junk yard type project, that might just shed some light on the modus-operandi of the 'its so simple you'll laugh Kapanadze box devices.
tinman
Quote from: Hoppy on April 07, 2015, 06:37:01 AM
Hey,the OU bit is comeing for sure lol.
Here is the second video,and we have moved a bit of bedini in there now. We are also running on batteries,and now ready for the big loop system setup. :D Note how the run battery voltage has climbed,even though we are drawing power from it,and not returning any ;)
https://www.youtube.com/watch?v=YWPJXqUFD4o
