Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 27 Guests are viewing this topic.
NickZ
   quote from MileHigh:
"Somewhere" and "nowhere" are synonymous in the above statement.  It absolutely matters where the excess energy allegedly comes from.  We have all sorts of ways of detecting and measuring energy in it's various forms."
        end quote.
  Then perhaps you can explain where the "extra" energy comes from,  when a magnet is passed by a coil.
As it's Not "coming" from the coil, nor from the magnet.  So, how can that magnetic flow be measured, to prove where the endless magnetic flux is coming from?
  As magnetic current is also the cause of electricity, or/and electric current, to begin with.
  So, please explain your thoughts on the real source of magnetic current or magnetic energy, which can also light high wattage bulbs, without being dangerous, nor being "hot electricity".
tinman
Quote from: TinselKoala on April 10, 2015, 11:07:49 AM
All you need is a tiny spark to set off a hydrogen explosion.... That's why it is always a good idea to have proper ventilation when charging LA batteries so that you don't get a buildup of hydrogen, neither inside the battery itself nor nearby outside the battery, like a battery box. And the power of the explosion will depend on the amount of hydrogen you've built up, not on the tiny spark that sets it off.
What happens if your capacitor or bridge rectifier fails shorted?
I would expect the RCD to trip,or just to have an open circuit.
As im using an SLA,there are no hydrogen fumes to go bang ;)
But i hear what your saying with the FLAB's.
So supposedly Clarence has a system were you can draw 200 watts from the mains and power a 1000 watt load.  Or, if you cascade two of them in series, you should be able to draw 40 watts from the mains and power a 1000 watt load.  Farking amazing.
Here is something that a lot of you believers without applying critical thinking, and believers without questioning, should do to give you a sense about what power and energy really are:
For starters, you can't forget that almost all of our electrical power at one stage in its generation comes from brute force mechanical power.  Just bloody brute force mechanical power, very unglamorous, like some giant ox turning a wheel.  You see a clip of overhead wires shorting out and sometimes it's a frighting and mind-blowing catastrophic explosion.  The clips are all over YouTube.  You will never take overhead wiring lightly after you see some of those clips when you see the potentially enormous amounts of power that can be liberated from those overhead wires.  That's because somewhere there is a giant 1000-ton spinning wheel that stores an enormous amount of rotational energy, but more importantly, it's like a giant inductor discharging where the discharging inductor is a literally unstoppable current source with the instantaneous power capacity of millions and millions of horsepower.
What you should do is connect an exercise bike to an alternator, and connect the alternator to a 100-watt incandescent light bulb.  Then get on the exercise bike and pedal and try to light the bulb at full power.  When you start pedaling, it seems okay.  However, when the bulb starts to light there will be some resistance in your legs.  When the bulb gets fully lit, you will be shocked at how much your legs have to work and if you are not a toned athlete with excellent cardio stamina, you will be lucky if you can keep the bulb lit at full power for one minute.
Instead of fantasizing and always gobbling up unfounded statements made by any free energy claimant that shows up on your doorstep, feel what it really feels like for your legs to put out 100 watts of continuous mechanical power for one full minute.  I am willing to bet that some of you would be shocked at this realization.  Then turn on your 1000 watt hair dryer, feel the heated air flow past your hand, and then contemplate what 1000 watts really means.
Clarence claims that with 200 watts, he can give you 800 watts of free energy.   That's eight Olympic-class runners and swimmers lined up in a neat row pumping away at their bicycle-generators - for free!  They just magically appeared out of thin air.  Contemplate the raw brute continuous mechanical power from eight Olympic athletes, and compare that to your shock when you got on the bicycle-generator yourself and you tried to keep a 100-watt light bulb lit for just one minute.
Perhaps that will help you understand, and give you some respect, for power and what it really means.  It's more than some unknown guy making text postings about some alleged clamp-on meter readings.
Quote from: NickZ on April 10, 2015, 11:28:49 AM
        end quote.
You have got to be kidding.  How long have you been on this forum?  If you can't answer your question yourself, then do the research yourself and teach yourself.  Since you have probably read the explanation hundreds of times, it obviously has not sunk in so there is no point in me stating it here.  Go to school, go to Google, get a book, whatever.  You have to educate yourself and then answer this question for yourself.
ramset
MH
yes Tommey Reed was doing some of that with His trike project..
also makes you appreciate just how much energy is coming from the sun.
1000 watts per square meter [ :o is it safe...???]
when a scrappy 20% efficient solar cell can do 200 watts ...
Plus we have this....https://www.youtube.com/watch?v=D39u9eeGG4c
its no wonder we have Bugs that can do this..
https://www.youtube.com/watch?v=eKPrGxB1Kzc
Soo
Clarence ..hows the chores going ??
Chet K
Thanks Grandma
