Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 28 Guests are viewing this topic.
truesearch
NTesla
I attempted a replication using 3 large toroid transformers, 4 turns each for the center wire loop, using a variac for input (~100 to 230VAC @ 50hz), with the ground connection as per the patent. Nothing out of the ordinary occurred. I measured the voltage on the output end and it was ~50VAC at about 200VAC. At 230VAC it was enough to light a 75W incandescent light bulb as a load, however the input wattage was not OU (or even close to it).
My ground wire was looped around the center wire - I also tried it connected, and also forming a loop like a 1 to 1 air core transformer.
Note that I did not use my household ground - instead I used a seperate grounding rod I use for HV stuff that consists of thick copper wire connected to a large fencing hinge buried in the ground which I water prior to use.
As is to be expected with so few turns of wire as the secondary, the center wire loop did heat up quickly.
Assuming the patent is valid in terms of producing OU via ground fed electrons, it may be that more sophisticated electronics/configuration is required for resonance etc. The patent mentions both AC and DC input are applicable however this may simply be a statement to maximise the scope of the patent.
John.K1
Truesearch:  Thanks for link. It looks very similar to Kapanadze. I understand a little bit what he say and the point was again to get right resonance. His device we can see is around 1 KW and he attempt to make a device 2-3 KW. Even if this is a fake I still believe it is possible to make something like that.  I think, point is to not think the resonance only but also capacitance,rotational magnetic field and the property of copper ( transmutation ability - kicking effect)
a.king21
I too have failed to replicate the Barbosa-Leal patent.
Under international patent law a patent is only valid if it contains sufficient information for an operative
skilled in the art to replicate the device.
Therefore these guys do NOT have a valid patent and anyone who discovers the secret
can patent their discovery.
Simple as that.
That goes also for Kapanadze.
Under patent law you are legally allowed to make a replication for your own personal use.
totoalas
Following the suggestion in yt
Instead of copper tube o wrapped .6mm magnet wire around 6mm cable
I cannot make a loop due to increase in diameter so i just inserted the cable in 3 secondary transformers and then connect the earth to magnet wire
I used 12 v battery inverter  and consumed 900 ma dc    to light a load of one 5 watt led lamp and no more light will light up
Direct 220 v ac produced the same cause no turns made in the 3 transformer
To control the avalanche current  loop cable must be onserted into a cpper or aluminum  tubing
Next test will be with microwave ovem transformer
