Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
tinman
Quote from: Farmhand on April 11, 2015, 01:41:33 AM
Well I can confirm that using a mutimeter on Ohms setting is not an accurate way to measure the resistance between two ground rods or arrays. And I'm fairly sure I know why because I've tried it and the reason became obvious to me very quickly.  :)
I'll leave it at that. If someone asks I'll explain what I think and we can then see if the trained guys agree with me. I would prefer either bringdown or Clarence to say why though.
No-you cant just use a DMM to measure resistance between two ground rod's,as the earth between the two ground rods will also have capacitance-much the same as a HHO cell. Your two ground rods act like the plates in a capacitor,and the earth as the dielectric.
http://cgiss.boisestate.edu/~billc/dielec.html.
You can how ever use a DMM if done correct. You will need 2 DMM's,a stable voltage source of known value,and a know value resistor. 1 DMM measures voltage across the known resistor,and the other DMM measures current from known voltage source to ground rod A. Then using ohms law,you can now calculate the resistance through ground rod A and B,as you have a known voltage source for the circuit,a known current flowing through the circuit,and a known voltage value across your known value resistor.
Pirate88179
Quote from: tinman on April 11, 2015, 02:01:20 AM
Excellent!  Someone should tell Clarence this.  Of course, maybe you just did.
a.king21
Quote from: MileHigh on April 11, 2015, 12:01:22 AM
I wonder where you get your information sometimes.  Telluric currents are just Lenz's law applied on a global scale with the power source coming from changes in space weather.  Just like the Schumann resonance is absolutely useless in terms of designing a free energy system, telluric currents are also pretty much useless also.
I get my information by analysing 19th century patents.
I also replicate some parts of them.
19th century patents required a working model. Where no model was provided this is clearly stated in the patents.
One little known fact is that you can stimulate the ground and create an ionic flow with it's own magnetic field. The term telluric currents is probably not the correct one in this case, but we do not have the vocabulary today.
It would have been nice if you had let Clarence carry on without upsetting the guy.
The fact that he had 0.1 volts between his earth rods was good scientific information to me, because it confirmed a measurement I had recently made between my two earth rods.
You  killed scientific investigation.
Congratulations. Job well done.
We don't need babysitters.
Pirate88179
Quote from: a.king21 on April 11, 2015, 03:04:02 AM
The fact that he had 0.1 volt between his earth rods was good scientific information to me, because it confirmed a measurement I had recently made between my two earth rods.
I can get 2 volts between my 2 earth rods and you can see this in my many videos where I light a floro tube, 400 leds, and run a motor.
Total BS on your part and you know it.
bringdownthezog
Quote from: Farmhand on April 11, 2015, 01:55:14 AM
Bringdownthezog, you remind me of a person that used to post at Energetic forum in the Don Smith devices too good to be true thread. With your plucking random schematics off the web and claiming they are Free Energy devices. Others will know the "Handle" I'm talking about.
Here is the code of conduct most of adhere to. You make the claim you provide the proof.
The schematic is in Russian or something so you'll need to translate that as this is an English speaking forum.
Farmhand,
You remind me of the drama queen Farah Day who used to demand proofs from everyone and getting quite upset with most everyone every day. Maybe she was on meds.
