Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 42 Guests are viewing this topic.
baroutologos
@leely,
First seek how a "one terminal oscillator" can oscillate such currents in-out from the ground. Milestone one..
ps: I realy need Verpies contribution on the subject
totoalas
And this pipe must be connected to earth ground . In the patent Barbosa Leal said the ground wire should be connected to the thick wire through magnetic induction . I believe also that the loads are not placed on the thick wire circuit but the circuit ground wire.
Reply ·Vote UpVote Down
    • Remove
    • Report profile image
    • Flag for spam
    • Block User
    • Unblock User
    Leonaldo Bezerra  Leonaldo Bezerra 1 day ago
      The secondary winding of the transformer coil should be such that you do two poles equals one for up and one for down. One side reinforces the field of the transformer and the other weakens . How this will happen in transformers inductor and coil you will have an avalanche current . And to control all this current to an acceptable level. Pass the thick wire inside a tube of copper or aluminum , which will cause a brake on the chain due to electromagnetic effect . be continue
    • Remove
    • Flag for spam
    • Block User
    • Unblock User
      Good afternoon , I've been studying the patent Barbosa Leal and realized I : 1 - The secondary windings of the transformers do not seem to be conventional , 2 - There are two transformers , one he calls the coil and the other inducer . The transformer coil believe this is wrapped in a conventional manner ( the counterclockwise ) . The transformer inductor should be wound this the opposite of the first ( clockwise ) . be continue
Hoppy
Quote from: Leely on October 11, 2013, 08:17:31 AM
So how do we draw the energy from the ground?
If we knew the answer to this, the Kapanadze thread would not be 1297 pages long!
MasterPlaster
I am so frusteraited I have forgoten the name of the Russian guy doing an experiment. Picture a car ignitian coil connected in the middle of two diodes connected in series.
Also I am beginning to think of the output coil of a Tesla coil differently.
baroutologos
All are eager to replicate Barbosa, Kapanadze or the frenchman's device that sucks energy from the ground in terms of oscillating current but nobody gives a sh...t IF its even possible via one wire to achieve that.
I have thought this in the past and tried unsuccessfully to just make it happen. You are all fond of Tesla's work but you do not even aknowledge this.. little bothering issue.
Actually indeed Tesla has suggested that and its found in his notes.
ps: we are not talking about free energy, just one terminal oscillator large capacitance
