Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 39 Guests are viewing this topic.
vrand
Quote from: Shokac on October 11, 2013, 04:29:25 AM
This is may first test of Barbosa device. It is very interestingly.
Where do you place the connections for output loads? Use any ground connection?
vrand
Quote from: totoalas on October 11, 2013, 08:37:01 AM
And this pipe must be connected to earth ground . In the patent Barbosa Leal said the ground wire should be connected to the thick wire through magnetic induction . I believe also that the loads are not placed on the thick wire circuit but the circuit ground wire.
Reply ·(http://s.ytimg.com/yts/img/pixel-vfl3z5WfW.gif)(http://s.ytimg.com/yts/img/pixel-vfl3z5WfW.gif) (http://s.ytimg.com/yts/img/pixel-vfl3z5WfW.gif)(http://s.ytimg.com/yts/img/pixel-vfl3z5WfW.gif)  Remove
Report profile image
Flag for spam
Block User
Unblock User
(https://gp5.googleusercontent.com/-9NRETR6-lCQ/AAAAAAAAAAI/AAAAAAAAAAA/ra9TIyZ6KXg/s48-c-k/photo.jpgLeonaldo Bezerra 1 day ago
  The secondary winding of the transformer coil should be such that you do two poles equals one for up and one for down. One side reinforces the field of the transformer and the other weakens . How this will happen in transformers inductor and coil you will have an avalanche current . And to control all this current to an acceptable level. Pass the thick wire inside a tube of copper or aluminum , which will cause a brake on the chain due to electromagnetic effect . be continue
Flag for spam
Block User
Unblock User
  Good afternoon , I've been studying the patent Barbosa Leal and realized I : 1 - The secondary windings of the transformers do not seem to be conventional , 2 - There are two transformers , one he calls the coil and the other inducer . The transformer coil believe this is wrapped in a conventional manner ( the counterclockwise ) . The transformer inductor should be wound this the opposite of the first ( clockwise ) . be continue
QuoteLeonaldo Bezerra  1 day ago
The transformer secondary to produce two equal poles should be wrapped as follows, start the first round, when you find the wire wich started the loop pass over it, down wire that is being rolled up, pass under the wire where it began coil and then all the way back to the beginning of the loop. This way you produce two equal poles. Do not forget that the other transformer all has to be exactly the opposite
Yes, the Barbosa-Leal patents shows North-South poles in transformers and lining them up NS-NS-NS in several configerations.
NickZ
  In my work and testing of the Exciter circuits "energy from thin air", as in the different Dr. Stiffler type of oscillators, I had placed a diode (or AV plug) on the earth ground, and found the the energy is "flowing" into the direction of the device, from the ground, and not to the ground, as in normal "grounding" operations. And this extra energy can be measured with a meter, and is also accumulative into capacitors, and batteries.
  Now, could it be that there is no actual "flow" going on, neither into, nor out of, the Earth itself? But, instead there is a polarization effect that is happening. Possibly, not of electrons, but more similar to Ions? Which are also similar to how photons can create light. And that this polarization effect is causing a polarity of this "static current", which can be tapped into, and utilized to make useable electricity. And,  it's this polarization process, and not a flow, as we are currently assuming, that is what is causing the bulbs to light. Without any "flow" at all, but with a polarity, similar to a magnet. As there are no electrons flowing in a magnet, yet most all known sources of electricity production are using magnets to create and manufacture electricity.
  Just as lightning can light the sky, yet, without traveling as we are being taught, still.
A polarization effect,  without any actual "movement", at all.  Static polarization.
  Think about it, don't let what we have been "taught" catch us with our pants down.
  If we are to figure out the cause and effect of free energy, we need to think differently, outside the "BOX", as it's not going to come from the same concepts as we have been taught, as when we are connected to a closed loop grid source.
  My contribution here is to instigate the idea, that, there is no movement going on, at all, but a "polarization process and effect" similar to a magnet, instead.
  Magnets don't run out of energy, because they are not the source of it. Although in time, their ability to create this useable polarity diminishes.
  Don't argue the point, please.  Just think about it...
Shokac
Quote from: vrand on October 11, 2013, 10:43:57 AM
I must first find the phenomenon to drive current from a short circuit.
Ground!  :) :)
No need ground, no need air. Energy from ground  :) :)
This is bullshit in Barbosa device.
This wire (grounding) use only for connect secundary winding of two or three transformer secundary.
Ground wire is the same like N-wire from Grid. Ground and N-wire from grid is the same potential.
vrand
Quote from: Shokac on October 11, 2013, 01:02:59 PM
Ground!  :) :)
Interesting, so don't need ground, that would make this design portable  :)
How many turns did you wind on your transformers with the new heavy gauge wire, wire size, photo of your setup?
