Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 41 Guests are viewing this topic.
forest
It depends what you need. If you need electrons then take it from ground or if you want to protect device from burning then dump excess energy to ground. Edwin Gray used deep cycle batteries but they often exploded....
vrand
Quote from: Shokac on October 12, 2013, 02:11:59 AM
Secundary must have min 2 turns, max 4-5. With one turn can not get the poles. Wire...... the thicker wires, higher currents will be induced.
Barbosa says that electricity must induce opposite poles from preset multiple windings.
Read all 4 patents, especially the one with the "air".
Fig.9 shows the circuit diagram of the device, indicating the effect of electromagnetic field.
Yeah the "air" patent translated from Pat Kelly's A Practical Guide to 'Free-Energy' Devices
ELECTROMAGNETIC DEVICE FOR CAPTURING FREE
SPACE ELECTRONS TO GENERATE ELECTRICITY
Application Number:  BR2013/000014
Publication Date:  07/18/2013
Filing Date:  01/11/2013
Assignee:  EVOLUÇÕES ENERGIA LTDA (Rua Santa Tereza 1427-B Centro - Imperatriz -, MA - CEP -470 -
Maranhão, 65900, BR)
QuoteObjectives of the Invention
The present invention aims to contribute to the  generation of sustainable energy, proposing electromagnetic
equipment capable of producing abundant electricity from an extremely low input of electrical energy.
The above objective and other objectives are achieved in the present invention by a device comprising at least
three sets of at least one electromagnetic field generating device (without a core or with at least one core)
powered by an electrical power source, having their cores or any extension of them, with their coils or sets of
coils, wound on at least one common conductive member in a closed circuit which is polarised by a voltage
source, and these sets of electromagnetic field generating devices are arranged with their poles in confrontation,
to promote the interaction of electromagnetic fields, and, preferably, positioned between two hollow metallic
hemispheres, in order to focus and enhance their electromagnetic fields - these interactions cause a new
technical effect - the emergence of an electric current which keeps flowing in a closed loop, with or without voltage
being applied to that closed loop, current which is capable of powering external loads - even if no load is attached
to it.
The device which is the object of the present invention operates as follows:  Sets of electromagnetic field
generating devices to be powered by an electrical power source, produce an electromagnetic field which induces
an electric current in a closed conductive circuit, creating an interaction between the magnetic poles, and through
repeated electromagnetic attraction and repulsion, provides an endless supply of electrons to the conductive
closed loop itself.
The electrons attracted by this technique, augment the  current flowing in the closed conductive loop, which
provides the current to power external loads of high power, in spite of the fact that the device itself is supplied with
only a small level of power.  Thus, advantageously, the device which is disclosed in the present invention forms a
trap for electrons from space, resulting in the generation of electricity. The interconnections of the components of
the electron-trap cause, a new technical effect, namely, the appearance of an electric current which keeps circling
in a closed circuit, even without any voltage being applied to the closed circuit
, and even without a load being
connected to it.  The present electromagnetic equipment generates electricity or thermal energy, providing access
to this new source of energy through the use of an electromagnetic field.
This design reminds me of the stove cook-top induction heating units of pots and pans to cook food. Here they use the transformers induction with an added closed loop coil to also create an electrical current loop to then tap free electrical energy. This also looks like the electrical version of Edward Leedskalnin's Perpetual Motion Holder with magnetic circuit.
vrand
Here is Fig. 12 from the "air" patent that shows their theory of the "electron trap" and how the electrons being repelled and attracted without resistance in a closed loop perceptual electric current flow.
Could it really be this simple to extract "free" electrical energy?
Back in Tesla's time there was common talk of free energy electrical devices to power homes and industry that were to be available to the public marketplace within a years time.
vrand
More similarities of the Barbosa/Leal "air" coil patent with Mark Steven and Tesla designs.
