Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
ramset
Additional Dragon Post and Pic
from here
http://www.energeticforum.com/renewable-energy/20091-barbosa-leal-devices-info-replication-details-10.html
Dragon
One to ponder...
This is for Clarence to ponder... others as well. I know you'll see it - I think your very close to opening the flood gates. I really had no intentions to build this but after re-reading the documents I decided to put together a small system using what I have based on the B&L theory.
Thanks Grandma
ramset
one more from  Dragon
from here
Patent # 690151 - also E.T.Jones earth antenna 1,372,658 is the one that started me in this direction years ago. Understanding Telluric currents helps as well.
Edit .One addendum from the Dragon regarding these circuits and posts
Dragon
Consider it an introduction to ground energy - learning about the earths potentials, a place to start learning about what Clarence is trying to accomplish. These circuits can be considered an earth energy detector. They are so stupid simple they really need no more discussion. Further discussion should be on connecting with the earth and ways to capitalize on what is there - the circuits mean nothing without knowledge of the actual source of energy, how to extract, manipulate and turn it into something useful.
_________________
Thanks Grandma
Grum:
Thank you very much for doing the tests.  That shows a very high resistance.  I don't know much about ground rods but I will make a few guesses.  I think I read somewhere that a standard grounding rod is about eight feet long.  I am going to assume that in most areas that are not in very dry climates it allows the grounding rod to make it down to the water table.  Perhaps not the water table but something like a region where the soil is permanently moist and just a few feet above the actual water table.  One assumes that then the resistance between two grounding rods one meter apart would be quite low.
I am absolutely NOT asking you to do that, I am more than content to guess at this point in time.  I can always do the research myself if needed.
Chet:
Thanks for reposting Dragon's information and allowing the blind to see the images.  It's fun and interesting stuff, a good learning experience for hobbyists.  The power levels are very low, probably less than one-tenth of a miliwatt.
The problem is that it has nothing to do with Clarence's alleged system.  That's always a danger with threads.  People start to run out of ideas and before you know it everything but the kitchen sink starts getting discussed.
