Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 40 Guests are viewing this topic.
stupify12
If the so called Energy from the Ground is Toroid Transformer as you showed on the picture. I know exactly how this Electro Dynamic Induction Machine=Rotating Transformer=Rotating Magnetic Field. In simple term it is the Lenzless Generator/Converter of Nikola Tesla which produce DNA like Waveform=means all loads will be in PHASE with the two Primary. TPU is another variation.
The converter only works with 2 Phase Alternating Currents for the Transformer has TWO sets of windings ( PRIMARY), 4 wound coils is connected in a manner that they fix the magnetic lines of field in 90 degrees.. The Converter/Transformer is powered with TWO Primaries on the toroid, the 4 coils is wound in a Asymmetrical Manner, Look for Patent Illustration of Nikola Tesla that you can clearly see the Windings e.g. 390,413 Figure 2 and 3. is a simple version which use only 3 TERMINAL  two different input of two Primaries with Common Grounding. This Transformer/Converter works like a Normal Transformer on any MERALCO Power Line which is Line to Ground(Earth).
Im about to build the Royer ZVS Oscillator to build the 390,413  Tesla Converter/ Transformer. The one you showed with 4 Terminal is power by DC input, with a special design of Commutator that will feed the 4 Terminal with a DNA like Squarewave. This design had long been documented and analyze together with my cousin when we have time to hang out. Read the patent but you will have a hard time to dig it out or understand the concept about that Converter/Electro Dynamic Induction Machine/Rotating Transformer/Egg of Columbus/4 Wound Coil Induction Motor of Nikola Tesla I think I already give you the origin of this device if im not wrong on what you mean. :o :o
Stupify :P ::)
Quote from: vrand on October 14, 2013, 02:15:29 PM
Thank you for the update.
10 mm cable is good to 239 amps for transmission (Maximum 328 amps for chassis wiring) and typically the insulation is rated to 200 C temperature.
http://www.powerstream.com/Wire_Size.htm
Does your 10 mm cable have insulation on it or is it bare cable?
Have you also tried the Shokac circuit diagram that he posted up this page, it looked interesting.  The Barbosa/Leal circuit looks simple but must be some special kind of hookup to made it work.
vrand
Quote from: totoalas on October 15, 2013, 05:51:29 AM
http://youtu.be/fJLfIrxYiBs
Thank you for the video of your latest Barbosa/Leal replication experiment.
How many coil turns per transformer? CW or CCW turns?  NS, NS, NS coil orientation?
Cheers
vrand
Quote from: stupify12 on October 15, 2013, 10:09:37 AM
Stupify :P ::)
Interesting, looking forward to experiments results  :)
"Hidden in plain sight" ?!
Over simplification take on my part, the shape and coil arraignments all looked similar to each other.  Some toroidal researchers have found that their is a VORTEX above the coil that can effect weather over-head, light sucking in clouds on a clear day and cause lightning to strike, yikes!
Cheers
totoalas
Quote from: vrand on October 15, 2013, 12:05:59 PM
How many coil turns per transformer?   2 TURNS
CW or CCW turns?   TR1 CW   TR2 CCW    TR3  CW
NS, NS, NS coil orientation?   NS  SN   NS
Cheers
slotinnn
I have read all the topics and none of you follow the schetces in the patent. I think then you will not achieve the results made by leal and barbosa. Ground wire how do you connect? a simple close loop ? or an open loop? like a spring?
how do you fulfill  the figure 6 in your tests? For the moment I have no ideea and no explanations.
He states in the first part of the description that the key of the invention is aditive induction in both cicles of the oscilations. Kind a tricky because in the same time he states it work in DC .
Don t even think this invention is not true.
Has anyone tried the patent as it is written? as it is shown in the figures? Results?
Theree problems
1 iduction connection
2. wiring of the second coil - those 2-5 rounds of wire
3. possible anything not shown.
We have the results- well shown.
We have some clues and figures...
We have to find the path to the final and good result
