Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Yuri_L
To understand how this "magic-loop" creates "Anti-Lenz effect",  I offer to redraw the "BarboGen"  ones more time with no shorted loop - Fig.6.
As you can see into the core, there are two fluxes Ф1 and Ф2 directed toward each other.
Flux  Ф1 is equal to   Ф1 = u*I1*400 (turns)*S/L
Flux  Ф2 is equal to   Ф2 = u*I1*1 (turn)*S/L
where u - magnetic permeability;
S - core section (cm2);
L- the length of the magnetic circuit.
Yuri_L
Let's do a short-circuit  the loop to set its current equal to 100A.
In this case, in the core are formed three fluxes.
In accordance to Lenz's law the fluxes Ф3 and Ф2 acts against the each other but also the "magic" flux Ф3 is consistent with the flux Ф1 and besides Ф3>>Ф2.
It is ALL secret of Barbosa.
We cheated Lenz's Law.   without a ground connection.
I have cheated third Newton's Law in 2011 :)
magpwr
Quote from: Yuri_L on August 01, 2015, 04:30:15 AM
In this case, in the core is formed three fluxes.
In accordance to Lenz's law the fluxes Ф3 and Ф2 acts against the each other but also flux Ф3 is consistent with the flux Ф1 and besides Ф3>>Ф2.
It is ALL.
hi Yuri,
I like your strong theory.Now if only you can show us your working model in youtube which tallies with your theory it would be nice.
Good Luck. .. ... .. . ..
Yuri_L
You can see a working example (8kWatt) of my partner (let see and  hear the sound of the transformer after 9 min 15 sec).
No-loaded transformer works very loud, but under load - its suond is wery low. This is the main work feature properly designed such an overunity transformer.
https://www.youtube.com/watch?v=WRZBO-LILlA
I ve already patented in Ukraine the principle of  Lenz-law compensation and will continue to publish the appropriate PCT application.
Best regards.
Void
Hi Yuri. Can you explain why you think there is a new third 'magic' flux, and why you think this will
be an advantage? I don't follow your explanation. Where would we connect the load in your diagram?
All the best...
