Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 50 Guests are viewing this topic.
Neofln
Forest... So you wanna make fun with me? No point of view is wrong until
it is refuted( you never tried to refute mine ). To reach results that
others have failed to get you must think different and  follow another
path. The greatest sign of wisdom is humility. Who is not wise is a
foolish, not a hero, and now you can laugh a lot. ;D The circuit that i
proposed, "IF" it works, dont close the cicle of energy meter, this will
reduce drasticaly your light invoice but probably not be over unit, maybe
this is what Barbosa and Leal got, a method to cheat the meter. I dont
know your place, dont know what type of meter the light company of your
place uses, but here in much places the companys still using the
eletromechanical meter. Have you know how a meter like this works? A
eletrical ac motor is connected in serie with the out of meter, when you
consume energy, the motor spins, Increasing the number on the meter, if
you dont close the circuit using phase and neutral, the meter can't
measure properly your consume because an ac motor needs phase and neutral
to work. This is the reason the phase from current transformer goes to
ground in the proposed circuit, just to have a new neutral to use with
load. This circuit was taken from interpreting the patent of Barbosa and
Leal in original, text and language. Remeber that u can ever translate a
text and replicate things but without information about how and where the
thing was made, and by who, you will never understand the thing that you
have replicated.
They can be genius or cheaters, by the way the second is more probably. In
their patent they don't talk about tests and measurements of over unity,
in their videos they show us, only that, with a small current of the light
company, they can measure much more in a cable, and get powered 6000w of
incandescent bulbs. So... The clip current meter that was used in the
vĂ­deos will really get bigger current in the secondary of a step down transformer with only
two turns of thicker wire, if u get it closed in itself doing a loop, and
if u get it closed, the tension goes to zero, so u can polarize like any
other wire, without getting the two diferent tensions destroying each
other. Now that u have big current polarized the current will flow trough
the closed circuit and the current transformer will work, u already have a
good phase to use in load, comming from energy company, so put that new
phase generated by current transformer in the ground, and use the new
neutral in pair with the energy company phase to the load.
Talking about heater version, its just a simple transformer with shorted
secondary, more the voltage in the thick wire more the heat in the core
and in the wire, so two more laps of thick wire. This one really can be
used to generate steam and move a turbine like in nuclear usines, but i
don't think that have any economic advantages.
Maybe that two guys don't know more than anyone and really don't know what
they are doing. I wanna test this to know if this is a cheat, or if is
over unity.
Next time u have something to test, first try to know the simplest way,
the simple way is 99% of times the right direction.
If you wanna talk about my bad english remeber first, that i can be
understood in 3 languages and understand other people in 4.
I had tried my first eletromechanical moto-continuous 24 years ago when i
had 8yo. This is my obsession and i have thinked many ways and years to do
something like this work.
I'm not an authority, but for sure I'm a newby only in the forum, and not
a clown. I come here to try help, and to get help, to learn, and share my
insignificant knowledge about the things, so at least I expect some
respect. If u found a error, show me, like I showed the foundations of my
thinking.
And if such conduct is permitted in this forum like you done, here is my
replica to your joke.
Who is the joke now? Regards from the monkey, foolish.
Remember that You is not MY hero, and to don't mess with me.
DaS Energy
Hello Neofln.
Don't be put off by that so few say, sometimes only one.  Usually a quick check confirms they have contributed nothing and pretend they are a somebody by writing shit as to why yours not work.  This is because they lacked the brains to suck and mother had to squeeze the tit or they'd die.  Now they so desperately want to be a somebody they pretend they have the intellect to knock others work. They want you to respond which is why they word things as they do. Then if you do their response discusses nothing said and comes out a complete new load of shit. They do this till your sick of replying.  On the plus side many many who agree with you not respond but take on board what you say.
Peter
ARMCORTEX
Neo plz.... That paint drawing is just that, a botched paint drawing.
dont write such long text its bad manners for forums, if you have an idea make it and see, no arguing necessary over a paint drawing.
enric
Neofln,
Guy, please contact me. We, at The Light Alliance, are trying to replicate that Barbosa Patent, and we would like to talk to you.
Please , include my skype or email me !
"enrictoledo" enric@aliancaluz.org
Grato!!!!
