Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
From the Herbert Adolf Zielinski list:
http://worldwide.espacenet.com/searchResults?compact=false&ST=advanced&locale=en_EP&DB=EPODOC&PA=adolf+zielinski
taking out this one:
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881212&CC=FI&NR=885754A&KC=A
and there are the coil-winding informations-for 900KW output- bringing down to 5KW output: Kg ?
listend above also the superconductor producing process -thermal shock-
Sincerely
              OCWL
nightlife
 They say their device will power homes and automobiles. With that said and it being noted that it is a mobile device, where does getting electrons from the earth come into play when it is portable and not attached to the earth?
Something sounds fishy about this. I can see someone being able to build a device that would attract a vibrance that would multiply a vibrance being used to create more power output then input but I dont think this is it. Atleast not as presented. The pending patent does not explain enough. Atleast not for me.
truongcongduc4
May I ask you this question ? I think it is not simple one or two turns for the earth connection.
havuhung
Quote from: truongcongduc4 on December 23, 2013, 01:09:06 AM
Hi All,
My idea is likely to be an large surface, thus absorb more charge transfer from the ground up, and see if the idea is reasonable, there will be composed almost a capacitor, not just a few turns of wire!
Regards.
FatBird
I think you are right, that it will take more than 5 or 10 turns.
