Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Liberty
Has anyone had a chance to test the patent app, as to whether there is a new novel effect to generate power?  I have read the patent and put together what I understand would be a suitable test circuit below.
It appears that one would want to limit the power input side, due to the closed loop on the transformer, will tend to smoke the primary without a current limit on input.  It would also seem necessary to extend the 2 coil winding to another transformer so power could be extracted from the circuit in the second transformer at a proper voltage output.
220v @ .1A
22wInputac     !-------------  output ac (should exceed 22w if it works)
    -----------------------___
                                      =   ground
                                      _
Liberty
hanon
Here a video with a replication of the system:
http://www.youtube.com/watch?v=lIF8J-Wj8fs
Liberty, I can not see your sketch because it seems to be moved by the formating of the text
Liberty
Quote from: hanon on August 17, 2013, 05:42:25 PM
From what I can see in the video, the replication only has a shorted loop.  You have to extract energy from the loop to see if it is more than what was supplied from the input circuit.  I can't tell that the video really shows any excess output at all, but it looks like his loop has a bad solder joint.
Here is my schematic drawing of a test circuit.
Liberty
Does that video show a connection to an earth ground? If so, I didn't see it. Can someone draw out the schematic of the video?
Liberty
Quote from: TinselKoala on August 17, 2013, 07:07:57 PM
I didn't see a schematic diagram either.  It would have been very helpful.  It appears to me that the primary on both transformers were being used for input.  I didn't see an earth ground either.
Liberty
