Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 39 Guests are viewing this topic.
havuhung
Quote from: MenofFather on January 04, 2014, 09:37:03 AM
Direction you can not know. I can ask you or water cold makes water warm colder, or water warm makes water cold warmer?
Hi MenofFather,
Thank you, for your hint is: Should the next step is to determine the voltage measured at a point in (Barbosa and Leal device) and earthing points.
FatBird
@Havuhung
How to know the direction of the electric current is measured in ampere clamp from a piece of wire?
Is to determine the current power line from the device is being run into the ground, either from the ground up equipment?
ANSWER:  The Current Probe has to be measuring current from the Patented Device BECAUSE the patent says insulated
                 Wire 5 is WRAPPED around Wire 4.
havuhung
Quote from: FatBird on January 05, 2014, 06:46:06 AM
@Havuhung
Hi FatBird,
What To prove that attracted the Wire 4 electrical grounding wire from Wire 5, the measurements do not have here?. .
FatBird
Here they light up 6,000 Watts of Bulbs.
Dave45
They must be using high voltage in the system, thats the reason for the rubber gloves.
Must be a Kapandze setup, air core or ferrite, ground wire.
