Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 66 Guests are viewing this topic.
truongcongduc4
Hello all,
More pictures to show you what I'm thinking. Remember that it is just an idea. And I don't know that: does it work or not ?
Please check it.
truongcongduc4
Quote from: forest on January 19, 2014, 05:26:19 AM
I have a different question... What is the rule to find the direction of current in secondary of transformer ? Is that the lenz rule ? From the last video the current direction was such that the resulting magnetic field was opposite to the source magnetic flux , N to N and S to S poles. Is that correct or the video had an error ?
If such then I ask : did anybody tried the transformer in such arrangement like in the last video but with two C like cores separated physically by a very small gap by adhesive tape loosely connecting them together ? If there are opposing poles inside core then it should try to break apart two C pieces pushing them away from each other ? IS that correct ?
Sorry for offtopic but I feel it is important to know that...
The last video just shows you "how the transformers work" in a very simple way. Please try to find another documents to understand the theory carefully if you think it is not correct.
My idea just talks about the loop, the coil (connect to the ground) and put them in the frame of transformer.
And you need to think out of the box. What will happen?
havuhung
@truongcongduc4,
These questions and your ideas prove that you do not have in-depth knowledge of the electricity industry class! . .
Những câu hỏi và ý tưởng của bạn chứng tỏ rằng: Bạn không có kiến thức trường lớp chuyên sâu về ngành Điện! . .
earthenergy
Quote from: truongcongduc4 on January 14, 2014, 01:19:27 AM
Hello all,
There is a man. He has succeeded with Barbosa and Leal device. (I hope so).
Please watch this video.
http://www.youtube.com/watch?v=eIu6tSoMh1Y&feature=c4-overview&list=UUVBBorUYaXxOd0gpdnwfDDg
Enjoy.
He posted the video several months ago and said he would update. He has not posted another word since. The video looked impressive at first with the ground wire looped around the closed loop windings but upon closer observation it also looks as though the ground may be connected to the copper as well. There is such a mess with the wiring you cannot easily see what is really going on. I believe he probably discovered he was running the load to ground, taking energy from the grid, and not getting anything extra. Otherwise he would probably have an improved device up and running by now and showing it to everyone. It is hard to believe it is a replication, unless he is doing a Tony Giang.....
IMO if Barbosa and Leal really wanted to impress the people they would use a small, pure sinewave inverter, to power the device, after all they are claiming 22 watts input and 6000 out, why would they want to use the grid to power the device? It does not make sense.
Time will very soon tell. If they can begin to sell devices and also manage to sign up manufacturers who have checked the device out, they will prove themselves to be legit.
a.king21
