Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
baroutologos
Quote from: e2matrix on August 18, 2013, 12:36:36 AM
Translation of the text by the video uploader:  "A brief example of how it would be possible to produce 100x more power using the new technical effect, generated by electro-magnetism that generates current by an electromotive force. This current keeps constant in the conductor's captor. I make it clear that I am skeptic and did not believe it was possible. But to my surprise I appears 300A using 2.3 amp consumption. Other experiments have already got 55 amp which would be more sensible to a residence. There is technically Induction respect to Lenz's Law. Now the amount of electrons which joins the driver where it comes?"
Can someone explain to that person that the hundreds amps (if correct measured) of the thick looped inductor is due to transformer turns ratio plain induction?
The weird would be if considerable amps would flow to the system, via one wire (as Kapanadze suggests) from ground to device.
But this is not the case is not it?
Where is the "inventor" to show us the principle? Instead every newbie tries to verify it.. sighh
Quote from: Hoppy on August 18, 2013, 07:59:53 AM
I think he switched the power on then off fairly quickly before removing the clamp for the reasons you highlighted.
And I think a very good and impressive demonstration of real power would have been for him NOT to have switched it off, and let it start glowing from the heat.
I've deliberately blown components to illustrate my points in videos.... and you can bet I would have supported a claim of a thousand amps with something other than an unstable meter reading from an unknown uncalibrated instrument. But that's just me, nobody pays attention to me, because I don't make claims I can't support with real data.
Here's a challenge: Put a 30 amp fuse in series with that cable and repeat the experiment. Or if you are really confident, use a 100 A fuse.
tinman
Mmm,im not sure on that one TK,it almost seems doable. I believe that cable could handle a 1000 amps for a brief period. Acording to the National Electric Code,you only need AWG 4 for 250 amp's.
https://www.youtube.com/watch?v=KQYFII5ESME
crazycut06
The video above is like a spot welding mod, high amps low voltage.... ???
MenofFather
Can anyone know to Barbosa and Leal transformer input put is DC or AC current? And can someone translate most inportant things in patents they?
And then shorted secondary wire, why consumption in his divice is 0,1 W? Current must increas with shorted secondary winding. And from were going output in they divice?
