Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Just..Sayin..
Quote from: Just..Sayin.. on February 09, 2014, 02:03:36 PM
I think in the beginning they may have just been inept. Probably they now see they have nothing and do not want to admit it. They should be able to run that 6000 watt 'captor' they claim is only consuming 22 watts, from a very small 'pure sine wave' inverter, not the grid, yet they demo a different unit that produces much less power that requires a very large inverter, that will only run for four hours. They have some explaining to do... that is why the expertise of the observers that went down there must be questioned, they should have asked to have the inverter power the 6000 watt unit and verify the 22 watt input.
hanon
I have checked the filing date of their patents, january 2012, and they have time to extend the PCT patent to other international countries until august 2014. So, I think that in august we will know for sure their credibility: if the patents are extended then it will mean that they have something great in their hands. If not extended then , or it is not great , or they have been paid a lot to bury the technology....Time will tell.
MURF077
There is something with the grounding loop, I take it the dotted lines represent a magnetic field. what if you continued to loop that hundreds of times insulating it from the "secondary wire" and induce a magnetic field onto the "secondary wire" causing electron flow...But its not a complete circuit you will say. you re ground the  coil a distance from the original coil ground and SWER could be the supplier or not
skribat
I asked for news to see if everything was ok, it seems they are under some pressure but I cannot be specific.
This is a reply I have just received from a close contact of the inventors .. I don't give the name of the contact because I was asked not to. ..
The device is called Captor as it amplifies electrical potentials from the planet. One need to give some electrical power at this is amplified about 90 times.
I have been talking with them and at next May they will be here where i live to demonstrate the technology. I And our NGO will buy one to be donated to a philanthropic institution.
Is out intention to publicize abut this in such  that the inventors can not anymore be treated and the technology can not be suppressed.
After this point a new vision about energy will emerge here in Brazil and we hope that this will spread...
