Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 59 Guests are viewing this topic.
RMatt
Quote from: forest on February 14, 2014, 05:14:28 AM
electrons are like water, you do not have energy in water, you need energy to pump water but if you had energy from outside which pump water on the hill then you get free energy by falling water , got it ?   >:(  this captor is a misleading to hide the principle behind capturing electrons, exactly like in Kapanadze devices there is no energy in dormant electrons, they are just a workhorse doing work by external energy
I believe there is energy in water. You seperate the hydrogen and oxygen, and use the hydrogen for things like hydrogen fueled vehicles, and other stuff ;D
Have fun all.
Bob
FatBird
@ Skribat,
Can you find out if the WEIGHT of 1.5 KG (for the 12 KW Unit) is wrong, because it seems like just the EMPTY BOX
would weigh more than that.
Looking at the Spec Sheet below, it says the 12 KW unit weighs 1.5 KG.  Something seems wrong about that weight.
http://energiauniversal.eco.br/
skribat
fat bird .. hi ..
everything I have read says 1.5kg, it does seem light but 6kw output is not really a lot, it might be right.  can I direct you here  http://www.project.nsearch.com/profiles/blogs/brazilian-firm-goes-to-market-with-free-energy-generator-capable-    for further information, you might find this interesting .. sk
FatBird
@ Skribat,
Thank you for that article site.  But still see if you can find out if the WEIGHT of 1.5 KG (for the 12 KW Unit) is wrong, because it seems like just the
EMPTY BOX would weigh more than that (about 3.5 Pounds).  Notice their Patent Photo below shows an Iron Core, which IMPLIES SIGNIFICANT WEIGHT
for a 12,000 Watts Output.
The reason that's important is because if that 1.5 KG weight is correct, it STRONGLY IMPLIES that unit has an AIR CORE rather than an Iron Core.
DaS Energy
Cant find the town of Empress-MA in any search engine. Can you please give country and location of town?
