Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
havuhung
Quote from: skribat on February 16, 2014, 07:01:33 AM
HI guys .. this is worth watching it is not ordinary free energy videos, I think this is not a magic trick.
http://www.youtube.com/watch?v=cUVvZzeDe5U  TIGER
http://www.youtube.com/watch?v=BvTWKHoncK4  PT2
Hi skribat,
This is just a magic show, these as Realstrannik.ru forum topics have been discussed respectively...
DaS Energy
Hello havuhung,
I find myself having that conclusion, which in some ways irks me as they built two companies around my knowledge, and the energy developments these companies have suffered a similar amount of query and mockery.
Amplification of energy is quite easy, put two wires into a tree and tap its amperage into a capacitor and you have enough power to run a house, however the duration is dependant on how long the amperage has been storing.
The inventors lay claim its straight wattage in and out yet their secrecy defies that. As for Patents there is no such thing as a world Patent, they are taken country by country, and many wont Patent unless your a citizen. The next problem is if you don't have the money to enforce your Patent its money pissed up the wall.
havuhung
Hi DaS Energy,
Principles that their patent refers to (extract energy from the ground), not logical to have a device running properly as what they are yet, they can try to hide a different principle if the device they are real! . . :D
FatBird
Here is some wording from their PATENT that sounds like their CAPTOR unit Charges a BANK of BATTERIES.
It looks like the FINAL OUTPUT comes from an INVERTER UNIT which gets powered from the Bank of Batteries.
My point is that it APPEARS the advertised 12 KW output comes from the INVERTER and NOT directly from the Captor.
Is it possible that the Captor charges the batteries ALL NIGHT so the inverter can power the house during the day? ??? ??
Why is this important?  Because maybe that explains why their Spec Sheet rates the 12,000 WATTS unit at 1.5 KG (less than 4 pounds).
Just the EMPTY METAL BOX must weigh at least 3 or 4 pounds!  So What's Going On Here??
Here are some words Directly From The Patent (which can be Downloaded below):
ABSTRACT:
The present invention relates to electric energy generation equipment comprising a basic circuit formed by a rectifier (10),
for example, an AC/DC converter connected in series to an inverter (12), for example, a DC/AC converter, and a bank of batteries (13)
connected in series between the rectifier (10) and the inverter (12). An electron-capturing element (14), which can be either a
free space electron-capturing element or, alternatively, an earth electron-capturing element, is connected in series to the basic circuit
formed by the rectifier (10), the inverter (12) and the battery assembly (13). The bank of batteries (13) powers the basic circuit because
it is connected to the system. Consequently, the inverter (12) converts direct current into alternating current and supplies this current
to the electron-capturing element (14). After receiving the electric current from the inverter (12), the electron-capturing element (14) starts
capturing electrons from the alternating current and powering the rectifier (10), which converts the alternating current into a direct current
in order to recharge the bank of batteries (13) and power the inverter (12) which powers the electron-capturing element, closing the feedback loop,
and also providing electric energy for consumption by external loads.
Click on this Link to see the Full Spec Sheet:   http://energiauniversal.eco.br/
Comments Welcome.
forest
