Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
ariovaldo
Quote from: kpannic on February 21, 2014, 06:27:55 PM
Hi, first excuse my English. I looked carefully this video:
http://www.youtube.com/watch?v=iRSP7h73u-Q
and diagrams from the patent.
1. They say in patent: the ground not a direct contact with the device. Take a look of the pictures with ground. I do not think that thick cable could do looping inside over the secondary looping. It's the same cable where measures the amps.
2. It measures only a single cable (blue) with that clamp meter. why not the black wire? see pic. Only the first device have input wire with two colors the rest not? Why the power cable have two color and the guy watch carrefuly when connect the plug???
3. At the last device, they show as the input 10amps (2200Watts) without loading and the looping wire with 128amps...again without loading.
4. My conclusion is that it is a scam. See my diagram and make the experiment on your risk. Look the diagram
P.S. Now I hope not as I think and is really a good invention.
I agree with you...There is a big chance to be a SCAM
Since I watched theirs videos, I raised my hopes to have something simple and cheap to help us, but it looks like that is one more BS. I still need to do some more tests and I'm planning to do that until the end of next month using a good ground system as the say that we need to have. As far I know, there is a test scheduled to be done until the middle of next month in Campinas (UNICAMP) to attest or not this "new effect" that is not more than the grounding cable looped around the secondary coil as they show in patent.
Ari
Shokac
Quote from: dllabarre on February 27, 2014, 02:07:35 PM
I know that with clamp meters the direction the wire goes through the clamps determines which direction you're measuring the current.
And the difference between the pictures is that all the wires do not go through the clamps in the same direction.
So he is measuring one of the wires with the current going in the opposite direction.
I don't use clamps meters so I can't tell you from the picture which way the current is flowing.
How about you just tell us in detail what you are seeing?   ;D
DonL
OK
In the first picture we see 22Amps in the lamp and 0Amps in blue wire (neutral from grid or inverter)
In the second picture we see 21,5 Amps to or from ground and 21,8Amps in black wire (hot wire from grid or inverter)
Electric circuit is close from hot wire, lamp, and ground, not from hot wire, lamp, and neutral wire.
This is secret of free energy or is cheating Electric company and close circuit before power meter? ??? ?
Shokac
ariovaldo
ariovaldo
dllabarre
Is that red/brown stuff what's inside the whole box?
That's one way to hide your secrets.  >:(
DonL
