Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 60 Guests are viewing this topic.
ariovaldo
Quote from: FatBird on March 03, 2014, 03:21:25 PM
@ Ariovaldo   (or anybody else that might know)
Below is some text from their Patent, converted to English.  Some of the HIGHLIGHTED words like LOOP, CLOSED CIRCUIT,
are REALLY STRANGE.  Is he saying that one of the Coils is a CONTINUOUS SHORT CIRCUIT? ???  Any comments?
Another advantage of the proposed electron-trap of the present invention is that the electron-trap can transport electrons from one
point "A" to a point "B", without a voltage drop in the link - if it is polarized - regardless of the distance between the points, depending
on the strength and quantity of the electromagnetic field-generating devices. It is also possible to transport the electrons when the link
devices generating the electromagnetic field are not polarized. In this way, the electric current is conveyed without voltage but only by the
magnetic field formed between the coils. This methodology can be used in various fields.
There is the appearance of an electric current, which keeps circling in a closed circuit, even without any voltage being applied to
the closed circuit, and even without a load being connected to it. The present electromagnetic equipment generates electricity or
thermal energy, providing access to this new source of energy through the use of an electromagnetic field.
The earth wire 5 is wrapped around the continuous loop wire 4, feeding it additional electrons captured from the ground. The ends of wire 4
are connected together to form the loop, and that connection also forms the positive side of the output (where a DC output is being produced).
The magnetic field produced by the current flowing in wire 3, acts on the electron flow coming from the earth, but it does not provide any of the
electric power flowing in wire loop 4.  The current flowing in wire 3 can be tiny, without affecting the power output.
Yes, the secondary has the leads in short circuit. The secondary pass through the toroid just once, but has 4 tuns.
Get 10 feet of thicker and flexible cable, type those one used in welding machine and make 4 turns. Before to close it a short circuit, pass thought once the toroid coil with 600 to 1000 turns ( it depends the core type and size) with 0.6 henries of inductance ..
This is what I can say for now
totoalas
So he used a toroid in the secondary loop ( high current with 4 turns)  and 600 to 1000 T  to produce load .  Battery cables or welding cables used fine strand to take care of heat...
like igor moroz IT induction alternatives  8)
FatBird
@ Totoalas,
Can you please make a little drawing or schematic and post it?
Thank you.
ariovaldo
Quote from: totoalas on March 03, 2014, 04:59:20 PM
The toroid is the primary...that is feed by the F and the N from the grid...
So you we have a primary with a high amps secondary.....
Best Regards
Ariovaldo
totoalas
Quote from: FatBird on March 03, 2014, 05:31:47 PM
@ Totoalas,
Thank you.
http://www.overunity.com/13721/energy-from-the-ground-self-powered-generator-by-barbosa-and-leal/msg372689/#msg372689
