Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 27 Guests are viewing this topic.
stupify12
1. The Electron Charge Funnel(Electron Captor) was design to be step down transformer into a usable Voltage, but the resulting Voltage is still High Frequency on my set up. If they had much more enough imagination they wouldn't need any battery at all ;D they needed only some high value Capacitor Bank as replacement of the Battery.
2. They filter the output into FWBR to charge those battery. The purpose of  DC output is to filter the HF AC that is very difficult to lower the
frequency. They had used the already made device for simplicity.
@ Ariovaldo. Why does your test fails  because you don't understand clearly what is the purpose of the Earth Grounding.
Kapanadze Quote: " The secret is so simple that you'll laugh" LOL  ;D ;D ;D
Quote from: FatBird on March 04, 2014, 08:24:32 AM
@ stupify12   or   Ariovaldo,
Both of you seem to know a lot about the Captor.  Looking at the patent diagram below, is this how they work?
1.  The Captor outputs a LOW voltage and needs to charge a battery.
2.  An invertor boosts the 12V battery DC voltage up to 230 Volts AC.
Does this sound right to you?
I am trying to figure out if the Captor can OUTPUT 230 V AC, ALL BY ITSELF, or just a LOW VOLTAGE and thus needs batteries.
Thanks.
ariovaldo
Quote from: stupify12 on March 04, 2014, 01:08:26 PM
Ok, you are right, I don't understand...
fer123
Mr stupify12, What do you think about having a toroid whit 600 a 1000 turns in primary( 0.6h is most important) plus big wire  for turns in secondary connected to?( other toroid, plus transformer for load all close loop whit big wire,  plus earth wire connected to load transformer?.
stupify12
There are Two Transformer. First Transformer Step UP the Low Voltage we input into HV. The HV potential then is feed to a Step Down Transformer, The Secondary output now is LOw Voltage. The Close Loop is Between the Secondary HV of the First Transformer and HV PRIMARY OF the SEcond Transformer Through Conduction of TWO Ground/Earth Points.
With the Two Ground/Earth Points the Oscillation we input on the First Transformer is being Tranmitted to the Second Transformer which at the same time the Electron they say is being suck up /Charge Pump/ Charge Funnel. The real reason why so many replicator failed to build a
This Transformer is the output seem to be no power delivered because all people think that this guys who posted circuit or diagram really tells them the exact and correct diagram.
For example the Picture which Barbosa and Leal showed on their Patent is not actually the working circuit compared to the Description I have given you on this Post.
We all know that there is a mass and very great energy stored on the Ground/Earth we only need to input a small amount of energy to disturb this Energy.
The Two Transformer is resemble like a AutoTransformer with STEP DOWN and STEP UP COmbination. More like what we have on our Electrical Distribution Line.
Quote from: fer123 on March 04, 2014, 02:06:21 PM
Shokac
Quote from: ariovaldo on March 04, 2014, 09:27:38 AM
As I said, I'm 95% sure the device doesn't work, but there is one more test that needs to be done and I'm waiting to build a good grounding system to test the "grounding loop effect".
OK!
Can you bay for me and for you ticket for Foudbal game of Croatia and Brazil? :-)
