Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
FatBird
@ Ariovaldo,
Since that is a junk Captor, can you take it apart more and post some photos?
Thanks.
ariovaldo
Quote from: totoalas on March 04, 2014, 05:02:18 PM
from the picture
3 meters of black cable  with a green cable looped around it same size   50 mm dia
the black cable is inserted into 2 big transformers ( like 2 MOT on top of each other )
the secondary  600 to 1000 T  inserted in the black cable loop for secondary output
lv secondary output goes to bridge rectifier then to battery   to  inverter
Loop grounding scenario
1. per stupify  2 grounds/ earth
    Electric company ground  . water tap /  earth wrapped on the HV   loop
2. electric company ground  to the primary  looped
   water tap  to  lv secondary   looped
   earth   connected to the HV  loop
which is which Stupify  Ariovaldo? ??? 8)
No high voltage...Just the primary that is a toroid with 600 turns and the secondary with 3 meters. The secondary pass just once inside the toroid....
The ground is not connected to the secondary high amps loop.
They used as a toroid core a electric motor stator.....
ariovaldo
Quote from: kpannic on February 21, 2014, 06:27:55 PM
Hi, first excuse my English. I looked carefully this video:
http://www.youtube.com/watch?v=iRSP7h73u-Q
and diagrams from the patent.
1. They say in patent: the ground not a direct contact with the device. Take a look of the pictures with ground. I do not think that thick cable could do looping inside over the secondary looping. It's the same cable where measures the amps.
2. It measures only a single cable (blue) with that clamp meter. why not the black wire? see pic. Only the first device have input wire with two colors the rest not? Why the power cable have two color and the guy watch carrefuly when connect the plug???
3. At the last device, they show as the input 10amps (2200Watts) without loading and the looping wire with 128amps...again without loading.
4. My conclusion is that it is a scam. See my diagram and make the experiment on your risk. Look the diagram
P.S. Now I hope not as I think and is really a good invention.
What I found until now, is not more than this, but once again, as I said, a need a good grounding system to test it.
My partner from Brazil just finished the grounding net, with 40 rods with 3 meters each one in a square lot measuring 20 X 30 meters....
Capisce??
Ariovaldo
ariovaldo
Quote from: ariovaldo on March 04, 2014, 05:40:43 PM
The toroid core...
Zeitmaschine
Quote from: stupify12 on March 04, 2014, 02:47:08 PM
There are Two Transformer. First Transformer Step UP the Low Voltage we input into HV. The HV potential then is feed to a Step Down Transformer, The Secondary output now is LOw Voltage. The Close Loop is Between the Secondary HV of the First Transformer and HV PRIMARY OF the SEcond Transformer Through Conduction of TWO Ground/Earth Points.
Two transformers? This reminds me on something like that (Stepanov transformers) in three-phase version:
