Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 31 Guests are viewing this topic.
fer123
thanks ariovaldo great contribution,  can you make a small schematic for all of us? Brigado.
stupify12
I posted what I have observe on the prototype device which I replicated from the works of Nikola Tesla. I was using 2 Ground/Earth for the device to deliver proper power output at the Step Down
Transformer.
You can drive it with simple flyback driver, mazilli driver, induction heater circuit, Tesla
Capacitor Discharge Circuit. Those drive is just actually the sustainer(kicking coil) for the oscillation to add up to
the Amplifying Coil.
Based on my observation on this device:
1. If ONE ground is disconnected the Load Bulb wont even light at its normal brightness.
2. If the TWO ground is proper connected to the device the Load Bulb will light very bright and very
hot to the touch. Can charge a battery so fast that you will get afraid the Battery will explode, the Battery readings from 12v will shoot easily to 26v.
3. I can assure that there is no harm to us who is getting near the device or handling the HV which
   is the result of Secondary being induced by the Kicking Coil.
4.The main features of this device is that the Magnetic Field of the Primary is away from the Loading Transformer Opposing Magnetic Field. I think you guys called this Lenzless Transformer.
5. This is a device Nikola Tesla disclosed boldly and clearly, I just test and replicated based on his
instruction. It is commonly seen on the internet.
6.You can add as many coils as you want on the Loading Transformer. You can add as many as you want Loading Transformer. Looping is nothing but so simple that you'll laugh.
That is the reason I can tell you guys that a Free energy device really needs Ground/Earth which is also the Plan of Nikola Tesla to send Currents through Ground/Earth.
I can assure you everything has already been disclosed by Nikola Tesla, The Energy Device is just an addition of the Looping Circuit or Looping Charger to charge your Drive Source or Battery.
Quote from: totoalas on March 04, 2014, 05:02:18 PM
1. per stupify  2 grounds/ earth
    Electric company ground  . water tap /  earth wrapped on the HV   loop
2. electric company ground  to the primary  looped
   water tap  to  lv secondary   looped
   earth   connected to the HV  loop
which is which Stupify  Ariovaldo? ??? 8)
dllabarre
Quote from: stupify12 on March 04, 2014, 10:28:43 PM
Transformer.
Are you going to provide us with replication information for your device?
Either way - Thank you for your work on this,
DonL
totoalas
I posted what I have observe on the prototype device which I replicated from the works of Nikola Tesla. I was using 2 Ground/Earth for the device to deliver proper power output at the Step Down  Transformer.
MOT for high amperage ???
Jonnydavros  1.5 v dc   flyback driver  5 to 82 mA
Checked  confirmed
hot to the touch.
split or single?
30 V  dc  like reactive charger
With proper connection  not alligator clips
Induction??
hahahahahah   like  this????
Water tap, Neutral, electrical compnay ground  and earth copper rod
Confirmed
Thanks  Bro    thats more like it  Pinoy way :)
havuhung
Hi ariovaldo,
Thank images.
Epoxy composites mixed with pebbles are hard to break! . .
