Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
totoalas
Quote from: ariovaldo on March 04, 2014, 05:40:43 PM
No high voltage...Just the primary that is a toroid with 600 turns and the secondary with 3 meters. The secondary pass just once inside the toroid....
The ground is not connected to the secondary high amps loop.
They used as a toroid core a electric motor stator.....
Muito bom   senior   no more imagination    obrigado  8)
Shokac
Thanks!
Where the load is connected?
My assumption is that it is connected to the loop and the ground!?
Why secundary is 3m long?
Shokac
fer123
What ariovaldo is showing is only a toroid whit 600 to 1000 turns in primary(0.6h) using a stator for it, plus 4 turns clockwise around the toroid exterior whit big wire passing only one turn inside (this is the secondary) closing tho loop, take from the connection one output, and the ground cable around one point the 4 turns the secondary, also connect to second output, if I am  wrong correct me please. Thanks.
FatBird
@ Stupify12
Thank you for your GREAT details post.  Can you please post a Photo and a Diagram (or schematic).
Thank you.
GCNG
In your opinion stupify12, what would it mean if in grid tests of Captors utilizing 3 phase power, one of the 3 phases is returning a large amount of power back to the grid while the other 2 phases are not returning power?
