Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 38 Guests are viewing this topic.
havuhung
Quote from: ariovaldo on March 04, 2014, 09:27:38 AM
As I said, I'm 95% sure the device doesn't work, but there is one more test that needs to be done and I'm waiting to build a good grounding system to test the "grounding loop effect".
Hi ariovaldo,
I'm still waiting for your test results on this device.
skribat
Quote from: totoalas on March 15, 2014, 11:22:16 PM
the big starnd in the cable is for the high amps high temperature
same as in high amps srating batteries
check igor moroz alternatives 1 and 2  using toroids  in the loop to release the load 8)
several experimentors/ inventors have said it is better to use a solid copper than a multi-strand if you can get it.  also most of these devices have two earth connections, water pipe and another ground wire ..  ie the galvanised  (zinc) water pipe, and the copper cable, these are two of the more efficient materials used in the ' earth battery ' .. I think this is a clue to the way it works.
Farmhand
So has no one tried this with bared conductors to make electrical contact between the high current loop and the ground wire ?
I guess not but I must ask why are people not trying this ?
I'll do the same as last time and create a LV 24 volt AC system which is a grounded neutral just like the grid is, by using a step down transformer to get the 24 volts, I will ground one LV leg to make it neutral then use the transformer to wrap the couple of loops of thick cable on to get a LV set up as it is shown in the diagram in the red square.
The last test I did I did not bare the wires. I used only my ground stake not the house ground system. This time I will try both, my experiment hut is a mess but I will video the setup to show the results anyway, as I think it is important to show just what it does do. I may need two days. I think there is a hand drawing back in this thread showing my last arrangement and how the LV grounded AC system is done.
I may also try using the grid 240v neutral and the grounded loop on my ground stake. I think I'll try that first, seems the most likely to show the biggest potential difference.
I think I might get their thinking. Some one needs to try it.  :)
Cheers
totoalas
1 wire charger an alternative to solar panel    yt     I used induction from a wall adaptor   in switched off position  and water tap  ... my caps charged up to 338v dc in 9 hours.....   that means the potential is there ....  either put this volatge in a coil / cap   and use the loop as in Barbosa
lots of possibilities   ... Farmhand s test ....   well see what happen.......
fer123
Working on It. Actually removed electrical tape and changed for tissue tape much better.
