Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 38 Guests are viewing this topic.
Google
A signature campaign by Barbosa and Leil on avaaz.org reads the following :
CEMAR ENERGY COMPANY MARANHÃO IS IN FRANCE TO CHASE THE INVENTORS CAPTOR ELECTRON: NILSON BARBOSA Cleriston LOYAL AND ABOUT TO DETERMINE THE PRISON OF CAUSING THEM BIG Bully
A CEMAR COMPANHIA DE ENERGIA DO MARANHÃO ESTA EM FRANCA PERSEGUIÇÃO AOS INVENTORES DO CAPTOR DE ELÉTRONS:NILSON BARBOSA E CLÉRISTON LEAL A PONTO DE DETERMINAR A PRISÃO DOS MESMOS CAUSANDO GRANDE INTIM
Whats happening guys, anyone knows about this in details ??
Best,
Google
Quote from: stupify12 on March 04, 2014, 01:08:26 PM
1. The Electron Charge Funnel(Electron Captor) was design to be step down transformer into a usable Voltage, but the resulting Voltage is still High Frequency on my set up. If they had much more enough imagination they wouldn't need any battery at all ;D they needed only some high value Capacitor Bank as replacement of the Battery.
2. They filter the output into FWBR to charge those battery. The purpose of  DC output is to filter the HF AC that is very difficult to lower the
frequency. They had used the already made device for simplicity.
@ Ariovaldo. Why does your test fails  because you don't understand clearly what is the purpose of the Earth Grounding.
Kapanadze Quote: " The secret is so simple that you'll laugh" LOL  ;D ;D ;D
Dear stupify12,
We all shall be very much obliged to you if you can please tell us in simple words, how to replicate the Barbosa and Leil generator, maybe for 100 to 200 watt output only.
You seem to be quite knowlegeable about Tesla patents and its applications in building free energy devices.
Please make a simple schematic, where we can buy radio shack parts and make a small working prototype with proper earth grounding etc.
Please make a schematic in which we can use a capacitor bank instead of a battery.
Awaiting your kind response.
Best,
Bruce_TPU
Hello ALL,
The truth is, I believe this device to be a "dead end".  BUT there is something to be learned when playing with closed current loops as it pertains to S.M. Kicks and the TPU is what I will tell you.
I have had over 200 amps in my current loop.  It will not go to ground.  Resistance of any sort kills the effect.  there is NO WAY to use the amperage, but ONLY the magnetic field associated with it.  Or the heat.  That IS the truth of the matter.
Once the current is in the loop, caused by Lenz's Law, it is not coming out.  YOU must think of HOW to use the magnetic field of said current.  That is all I can say.
Ground from the current loop is a WASTE of time.  In my humble opinion after MUCH experimentation in two labs.
Play with closed current loops and think for yourselves.  Tedious, but not hard.
Cheers,
Bruce
Olivegus
Quote from: lancaIV on December 19, 2013, 05:48:52 AM
                     Happy birthday -25 years jubilee- open source :
[0040] To clarify the operation of this embodiment according to the in-vention, the following dimensioning of the transformer windings is given using Figure 17 as an example, the iron cores being dimensioned in accordance with the manner usual for transformers:
- winding 81: 100 windings, 220 V/50 Hz, 5 A at full load;
- winding 82: 1 winding, 5000 A;
- winding 84: 1000 windings, 5000 A;
- winding 85: 1100 windings, 4500 A, 220 V/50 Hz.
[0041] From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84. Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1.1 kW, and this corresponds to a power gain of approximately a factor of 1000
        superconducting= super low resistance
Sincerely
              OCWL
hi, do you have a video of this please / and can you prove these findings? thanks.
Google
Dear Bruce,
Can you suggest a simple circuit schematic to make a current loop to generate high magnetic field. Actually most of us are sort of dumb and do not understand riddles. And there are already enough people who have been talking in riddles on the overunity forum since many years.
Entire humanity shall be grateful to you if you could free us from the shackles of energy elites ruling the world. Your name shall be written in golden words in the history of energy generation.
Best,
