Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 28 Guests are viewing this topic.
skribat
Quote from: totoalas on March 19, 2014, 09:28:10 AM
thanks fir ur analogy
why wait for free energy  if u can do it hybrid   while still waiting for  one
in a 3rd world country where 85 percent of their hard earned money goes to utility bills instead of food
this a step in right direction
like you said  to share ur formula for making gold in the lab
would that be better and ur name will be remembered which was said by you
if ur living in a free country  we can do what we want
so ill settke for more tests  on the barbosa leal as others are
hope you can contribute with ur own   thanks
[/quote
whatever you believe you must watch this ..  http://www.youtube.com/watch?v=e92yz5Y1img   ***
Google
Wind an ordinary heater element wire around the phase wire of the grid in your house, it should not touch the phase wire anywhere. Connect one end of the heater element coil with a cap and other end of the cap to earth. Other end of heater coil wire should be left as it it, not connected anywhere.
Have free electricity, unmetered, for as long as you want.
For better results use thick copper or silver strand.
If in your country you have neutral return wire system :
Make a deep dug earth connection, put a copper rod in it connected witha thick multistand cable as used in battery connections to inverters. Let this wire be deep buried in hole with rod. Do not remove cables insulation till atleast 4 meters deep. Fill the whole with concrete. Let it dry.
Now check the potential difference between phase wire and earth you created. If need be add an automatic voltage trafo in between, say 5kw, to power your house load.
Check energy meter reading before and one month after.
Best way to free energy for third world.  ;D
Ps. Totoalas, you forgot I clearly mentioned that if Tito shares his free energy device I will tell my heavy metals to gold transmutation formula. No alchemistry, pure physical chemistry.
Best,
Have fun.
Google
Still better way, make a tunable RLC circuit with natural resonance at 50 or 60 hz and suck free wireless power from the grid.  ;D ;D ;D ;D Formulas available all over the internet. Put the recieving coil on you roof.  ;D ;D ;D
Make multiple FM crystal radios tuned to your local FM station, use tuned dipole antenna with good earth and dump their out put to a cap and charge batteries with it.  ;D ;D ;D ;D Free energy from thin air.
Wear shoes fitted with piezo speakers at the bottom, all connected to a super cap. In the night switch on small LED lamp headlights mounted in front of your shoes. Free energy. Shoes with headlights and red tail lights.  ;D ;D ;D  ;D
Not joking.  ;D ;D
Google
Anogher bright free energy idea : Order meter jamming remotes from China or bribe your friendly meter reading man to put a slow moving meter on your line.
Another clever hybrid overunity way of free energy. ;D ;D
totoalas
nice tip Google
if you can also see why  meters are installed   20 feet above ground power companies meter readers use vernacular lense to read meters on top of 20 ft poles  to eliminate meter tampering
Using two bladed hook with stone as weight on a passing two wire  elecrc utility  cables   wellla   free lighting and tv at night
Slider just uploaded his 1 wire dc led lights @ 50 feet   using battery    so theres a chance
now back to Barbosa
lets do it
cheers 8)
