Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 59 Guests are viewing this topic.
Google
Quote from: totoalas on March 19, 2014, 11:11:13 AM
nice tip Google
if you can also see why  meters are installed   20 feet above ground power companies meter readers use vernacular lense to read meters on top of 20 ft poles  to eliminate meter tampering
Using two bladed hook with stone as weight on a passing two wire  elecrc utility  cables   wellla   free lighting and tv at night
Slider just uploaded his 1 wire dc led lights @ 50 feet   using battery    so theres a chance
now back to Barbosa
lets do it
cheers 8)
http://blogs.dunyanews.tv/?p=6991
Google
havuhung
Quote from: Google on March 19, 2014, 10:26:05 AM
Wind an ordinary heater element wire around the phase wire of the grid in your house, it should not touch the phase wire anywhere. Connect one end of the heater element coil with a cap and other end of the cap to earth. Other end of heater coil wire should be left as it it, not connected anywhere.
Have free electricity, unmetered, for as long as you want.
For better results use thick copper or silver strand.
If in your country you have neutral return wire system :
Make a deep dug earth connection, put a copper rod in it connected witha thick multistand cable as used in battery connections to inverters. Let this wire be deep buried in hole with rod. Do not remove cables insulation till atleast 4 meters deep. Fill the whole with concrete. Let it dry.
Now check the potential difference between phase wire and earth you created. If need be add an automatic voltage trafo in between, say 5kw, to power your house load.
Check energy meter reading before and one month after.
Best way to free energy for third world.  ;D
Ps. Totoalas, you forgot I clearly mentioned that if Tito shares his free energy device I will tell my heavy metals to gold transmutation formula. No alchemistry, pure physical chemistry.
Best,
Have fun.
Hi Google,
If someone's done according to what you said above, he would be the power supply company accused of: (electricity theft)!  ;D ;D ;D
                                   PS: Free energy in this way is not okay!!!
totoalas
Quote from: Google on March 19, 2014, 11:27:46 AM
Link please ..
Thanks
dc single wire transmission   and  dc single wire  -  50 ft from solar     yt     slider 2732 8)
Google
No its free energy by induction. Anyway power company has induction losses. I can sue power company to irradiate my house with unwanted radiations.  ;D ;D ;D ;D
