Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Zeitmaschine
Totally passive? Same as the Stepanov device. Can anyone see more than two transformers and a capacitor connected to a disk saw via two power meters? I can't.
Taking a closer look at the carpenter transformers. The three-phase transformer (white) next to the three-phase capacitor (dusky pink) is not fully connected. It looks like a step-down transformer but the secondary low voltage high amps coils (thick white wires) are all open. Hence my guess is that the primary coils of that transformer are working as three-phase chokes in resonance with the three-phase capacitor next to it.
Then what's the second transformer for? Does this transformer perhaps provide high voltage? Just 2 to 5 KV, not real high voltage? So could it be important to have an electric field of a few KV 50Hz sine wave in resonance with the LC circuit formed by the chokes and the capacitors? Could it be that the cable 4 is the HV cable coming from the HV transformer and the cable 3 provides the primaries of that HV transformer with 380V?
What could happen if an electrostatic field of one transformer (HV) is mixed with an electromagnetic field of a second transformer (LV)? Could the calculation »electromagnetic field times electrostatic field« be responsible for the generation of those strange observed ground currents?
ariovaldo
Quote from: fer123 on March 21, 2014, 08:05:29 AM
Mr ariovaldo are you planning to replicate the toroid the same way you find it, what is the best ground system do you recommend for this system?
Yes, I will do some more tests even knowing that in the original equipment didn't work with the original owner and didn't work with me. The original owner had a good grounding system but I didn't see how was the tests and connections. When I tried, my grounding was not good like they use to ask for.
The excuse that Barbosa gave to the original owner was the inductance in the primary was not right. The inductance was 0.21 Henries and was suppose to be between 0.6 and 0.8 Henries as I told before.
The grounding system that they asked for is 40 rods using 35 or 50 mm.
Area 30 X 50 meters.
MenofFather
Quote from: ariovaldo on March 21, 2014, 07:15:36 AM
One more picture..
Cheers
Ariovaldo
Maybe they getting energy from cureent transformer, like Arkadiy Stepanov?
