Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 45 Guests are viewing this topic.
leo48
As you think I can not figure out how to work the captor of electrons, as far
as I know the magnetic field does not attract electrons but also makes them
deviate if they are on the move .... so I do not understand how it can work ... :o
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Neo-X
@totoalas
Did u use copper wire as thick as the thumb? I think if we follow exactly what is in the patent we can replicate it. Maybe fine wires cant draw electrons from the earth.
havuhung
Quote from: truongcongduc4 on April 01, 2014, 11:26:48 AM
The red chemical is plastic, right? I think the equipment will not work in the air. Could you please analyze it?
@truongcongduc4,
Epoxy resin filled into the device, only with the intention of making it difficult for those who want to find out which device structure how! or hide the details in it! ;D
totoalas
Quote from: Neo-X on April 01, 2014, 10:38:42 PM
@totoalas
I use 6mm fine stranded    for mot  i will use mm50mm dia   battery cable same qs urge thumb  for high current
I think it's not the fine wires but the induction  on the core  plus earth  will boost the output
In my e core with ring magnet in the center  i use the hv from ignition coil to connect to the e core with and an extra coil in the primary to boost the mac from ignition137 to boost
Mac from 137 to boost340 v a.c.
From erfinder   he says
Recover the recovered energy back to primary  to double kick  which i did with ignition coi
A gap surely help   a spark gap using hv arc instead of relay
Now try that simple  test
Capture the v from the loop and an1 wire from the earth  and let us know urge result 8)
