Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Neo-X
Quote from: havuhung on May 07, 2014, 06:29:55 AM
Hi Neo-X,
Transformer 220/110 of you are testing; What happened that you mentioned above, may be between the primary winding and a secondary winding insulating layer of paper had no good! . .
I dont know how it happen. I was thinking the transformer is not really an isolation but a stepdown auto transformer.
havuhung
Hi Neo-X,
It is an auto stepdown transformer, you draw a wiring diagram  transformer, how to connect the ground wire from the transformer  you've done? 'll see why Increasing voltage 110 up! . .
Neo-X
havuhung
Hi Neo-X,
Maybe you have the wrong wiring is like this! . .
The source 220v, hot wire is at the top of the picture and the neutral wire at the bottom of the picture.
Neo-X
Quote from: havuhung on May 07, 2014, 09:33:31 AM
Hi Neo-X,
I test the primary and secondary with multi tester if there is a connection between two and there is current flow so meaning it was really an auto transformer. Luckily i put the ground wire to the top end of the transformer if its on the other end it will explode high a huge spark.  ;D
