Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
NickZ
  Nenad Savic shows a Barboza replication having a 48watt input, and 2100watt output.
  Anyone that can speak and write his language please invite him to come to this thread and tell us more about his circuit. Please...
Edit: I had not seen that the links had already been posted.
   https://www.youtube.com/watch?v=ARkj5ee7NT8
x_name41
Quote from: NickZ on June 03, 2014, 02:16:26 PM
aaaa, yes, yes, in the video the Serb says that has repeated the scheme provided by ariovaldo :)
Farmhand
Quote from: FatBird on May 04, 2014, 08:16:20 AM
This Brazil Captor unit is just FOOLING THE METER.
If you Follow the Mains HOT wire (wire 1) down you can see that it exits the OUTPUT (wire 4).  This is the SAME MAINS HOT WIRE.
They Fool the Meter because the Output uses the EARTH GROUND and NOT the Mains Neutral, thus FOOLING the Meter.
However, I suspect that their units CANNOT fool the New SMART Meters being installed around the world.
The coiled Black Wire serves NO useful purpose EXCEPT to show around 125 Amps circulating in itself.  EXCELLENT for fooling people though.  LOL
---->   A VERY SPECIAL THANKS goes to Mr Ariovaldo for BUYING a Captor, taking it apart, and Drawing the SUPER GOOD Professional Schematic (see 3 posts above).
There is an easy way to see if the neutral wire is being bypasses and the grid meter fooled. Simply use an in-line safety
switch/residual current device (RCD), out of the socket being used, I did and with the active wire connected through the device
and returning the current through the ground the safety switch tripped immediately because a mismatch of current was detected
between the active and neutral lines back from the socket.
If the house is not fitted with any safety switch device it is possible to bypass the meter, however doing anything with live grid
power without a safety switch fitted to the house or without using an inline safety switch is madness.
Without seeing an in line safety switch (and test tripped) we have noway to know if there is one being used.
This is what one looks like but a single socket one can be had for about $20.00 that's a cheap second chance at life.
http://www.arlec.com.au/viewProduct.aspx?productcode=PB96&catalogueID=2&parentCatalogueID=2
x_name41
Quote from: Farmhand on June 03, 2014, 05:51:17 PM
not, you are wrong!, in a first video, white power cord is designed for a 2.5A, he is not calculated for 2.3KW!
Farmhand
Quote from: x_name41 on June 03, 2014, 06:12:20 PM
I don't understand your post. What does the white power cord's designed power rating and "he is not calculating for 2.3 kW"
have to do with weather or not he's using a safety switch ?
Is he using a safety switch or RCD ? You tell me and show me your reasoning.
