Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
x_name41
Quote from: Farmhand on June 03, 2014, 06:51:57 PM
I don't understand your post. What does the white power cord's designed power rating and "he is not calculating for 2.3 kW"
have to do with weather or not he's using a safety switch ?
Is he using a safety switch or RCD ? You tell me and show me your reasoning.
well Farmhand, but let's point out that this white power cord may miss 2.5A max., This cable can not misses 10.45A (for 2.3KW), if actually the output is powered directly from the phase trough grounding
fer123
He is talking from video replication the power cord will not resist 2.3 kw, the current is coming from earth.
fer123
This topic will be solve if somebody show this system from battery and power inverter.
x_name41
Quote from: fer123 on June 03, 2014, 08:09:15 PM
Of course, if supplied with power from a battery (through power inverter), could not be fraud, because it does not use the phase of grid
Neo-X
Last night i made another replication attempt of this. This time im ensured that i use isolation transformer and i follow the patent of barbosa exactly but still i cant detect any voltage and current in the output. Then i discover that one of our power line is grounded outside near in the post when i test its voltage it gives 225 volts when i connect one of the outlet to the multi tester and to the ground. I test the outlet voltage and it gives only 220 volts. Now why it has an excess of 5 volts? Is it possible that the ground give extra voltage? What if i increase the frequency will the ground give more voltage like teslacoil?
