Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
a.king21
Quote from: FatBird on August 20, 2013, 08:26:13 PM
Is there ANYBODY that can post a SCHEMATIC or Circuit Diagram about this circuit??
The circuit diagram is on page 4 by Hanon.
Input at the top, output at the bottom.
e2matrix
Quote from: a.king21 on August 20, 2013, 10:00:36 PM
That and there are plenty of details and diagrams in Patrick Kelly's latest update of Chapter 3 of his Free energy book as well as the text of the patent in his Appendix now maintained by Lamare at http://www.free-energy-info.tuks.nl/  where you can download the book, chapter and/or Appendix.
e2matrix
I gave this a quick and dirty half hearted try.  I think I spent a whole 15 minutes on it.  I don't want it to discourage anyone from trying as it was a one shot quick try.   I used an outside ground rod separate from the house electrical ground rod (although they are both close to the house) that is 8 foot long completely in the ground, copper clad type.   I used a big MOT that was being fed from an isolation 1:1 transformer into the MOT secondary (high turns of fine gauge wire).   I tried the primary of the MOT with the ground wire (12 gauge) wrapped around it.  I also tried running a separate wire around the secondary with just 2 turns and tried the ground wrapped around it.  Initially I was getting about 0.2 volts but I then reversed the input wires (think neutral and hot in house wiring) and I then got about 2 volts.  I then tried hooking the ground directly to the 2 loop wire and saw 12 volts but not enough current to even light a little 5mm LED.   I couldn't see any amps on my meter but I think when I went to the Fluke microamp scale I saw 1/10 of a microamp.   So that should be enough to run my house  ....   LOL.
I could see there would be a lot of other ways to go about this and a whole lot of things I didn't try yet so don't let my quick test discourage anyone.   It's really a simple device if there IS anything to it.  I'm not sure I have all the details right and there is also the possibility that like most patents they hide something to make it less likely to be copied.
Pirate88179
e2:
Wow, my earth battery outputs more than that  and I have been able to light 400 leds, a 48" floro tube and also run a Bedini motor from it.  (Not at the same time)  I still don't see where these guys say the power is supposed to be coming from?
Thanks for reporting your tests.
a.king21
Latest Barbosa leal video today.
http://www.youtube.com/watch?v=Gb_xrj2y7Vg
Published on 23 Aug 2013
Power: 39.6 kW 220V
Generation capacity Month: 28,728 kWh
Equipment installed: Industrial application
If this is a patent investment free energy scam, it's the king of all free energy scams.
BTW I can't get it to work either.
