Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
nelsonrochaa
Hello Wayne.
It is important to differentiate the active power (watts) the apparent power (volt per amp), for what we pay is the active power Watts.
In some countries the energy returned to the network (reactive power VAR) is also charged.
Always said that the vessels of generic measure such as ammeters and multimeters only measure apparent powers except in true rms measuring devices.
Meters (such killwatts) measure the active and apparent power because are true rms.
It is known that the reactive power generated in the operation of a motor or transformer which is usually returned to the network is not able to produce active power according to current science explains and generating large amounts of heating in inductive loads and in all circuit.
  When the power factor is corrected and that the optimal value (1 is best) all the reactive load does not return the network being used less active power to make the job because the apparent power reactive power is reused at the source.
Now think with me:
If the reactive power causes heating of the electric circuit in the unit that generates and causes distortion of the sine wave AC making companies apply charges based on the power factor forcing the user to maintain maximum values ​​close to 0.78 (depending on supplier) what do you think if all inductive and capacitive devices have an ideal behavior which is always 1? This will be great ok ?
If the reactive loads do not produce active power (Watts) because it is so unwanted by the companies?
Because heat conductors requiring the use of larger conductors? The harmonics created that distort the quality of the grid ?
Heat on drivers is synonymous with? Joule effect. :)
But they say it can not be harnessed and converted to active energy! For they say, and many other dubious explanations.
Never mention that my circuit is overunity. Never
And so I can do other types of tests, will share results. Currently has several contacts in order to sell the device (These people are crazy lol) and for that reason I can not dissect the circuit in detail.
I think later and in order to finance my tests I can put up for auction on EBAY the prototypes.
Always said that the original patent had important data, including the bibliographic references made ​​sources used in the preparation of patent barbosa.
I can not say much more about this project.
And say something clearly:
I've seen many circuit diagrams to run the internet and only serve to confuse even more people.
Do not copy! Recreate and abstracts them from the real world and  of laws imposed.
Know very well what has happened to the most notable inventors who wanted to change the system. Were abandoned by the scientific community, were murdered, were persecuted and most other things that are common domain.
Never assert publicly that the system works for free energy ! and I'll never tell.
How  say Scolari:
And I'm dumb?
Its a joke made by Scolari when train Portugal football team to a reporter. :)
Man good luck in your experiments
nelsonrochaa
viejo loco
muchas gracias nelsonrochaa  pero pon esquemas que nos tienes en un estado de crisis nerviosa :o
esquemas muito obrigado nelsonrochaa mas você nos colocar em um estado de colapso nervoso  :o
many thanks nelsonrochaa schemes but you have put us in a state of nervous breakdown :o
