Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
nelsonrochaa
Hi , the circuit that i past links don't absorb energy from grid because is static energy.
for this reason you can sure that wont count in your grid meter.
thanks
pavqw
That's perfect. So I don't understand why it is not used widely? Well it seems as you can get theoretically unlimited power or am I wrong? There should be a limit.
Do you think there is some negative property so it can't be used to supply more devices in home?
nelsonrochaa
hello pavqw,
The basic problem is that energy can not be charged $ :)
For this reason it is not widespread.
Yesterday I read an article that left me wondering where someone wise and excellent ability to scan said the following:
On the day the power is free the world had collapsed.
And he has every reason, society as we know it, is deeply dependent on the silicon, electrons and electrons ... this makes with all the economic and social foundations that support society are directly dependent on electrical power.
From one day to another would be the global source of a strong global collapse of all financial structures that would eventually reflect on all of us.
However it is just a theory :).
pavqw
Indeed it could be true.
By the way, just small idea comes to my mind.
If previous device will work, and it seems it will, then if we can generate for example A/C voltage and supply with it our free energy device (so we swap the grid line to self generated power), we should get self looping behavior.
Generator should be powered from Free Energy device.
Free energy device can't drain power from the generator, so it must work. But I am afraid it is not so easy and we can't achieve overunity here. Generator has to be very efficient and probably with specific characteristics and maybe some load attached?
If I am correct, it seems the higher load is in grid the more free energy from the device. So if nothing is connected to grid we can't get free energy from this device.
nelsonrochaa
Well, we can say that it is a difficult task to achieve overunity .....
at least the explanations of conventional science.
But we also have proven for more eccentric people in this branch of science that 1 +1 does not equal 2 :).
What I mean is all very questionable depends on the person's perspective. There are people who are completely formatted and do not even bother to test and question why some phenomena visible in our day to day happen.
Regarding your reasoning on the fact that the electrical network connection does not exist and the circuit does not generate power as soon not be overunity,
makes sense in this particular case because the circuit only compensates the local load used reducing the power consumed in the power grid however the effect is there, this is the most important! Now if the circuit is designed to store the surplus somehow allowing self-circuit power will have to be designed differently than what I'm trying to do now DC pulsed.
Never intended to prove that the circuit causes the electric meter misread the consumer's favor but rather to demonstrate the effect and works very well :).
As I said today to a subscriber of my channel this is just a drop in the ocean.
Still so much to understand, test, in this matter.
One thing I can guarantee:
In my humble opinion it all boils down basically the same.
Everything depends on the back-emf and resonance, something that is not easy to attain as they are not visible phenomena in everyday life.
The people in your life period of time have less time to be attentive to the smallest details; everything has apparent explanation :) so why try?
No, we buy buy .... The great lords of money keeps us busy and distracted to consume and work.
This is the system:)
man i work in my own researches about 15 years and i see every time new  phenomenas and i learn with that.)
bye and good mad science ;)
