Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Marsing
nelsonrochaa
Hi Andrea bor ;
In my setup i use a conventional primary coil 220v ac transformer but i think that if increase the turns will reveal changes in result, but in my setup a use a conventional toroidal core without original secondary layer .
I try another cores like a MOT but i think is not so efficient to make the secondary.
I have planes to make a new video with a MOT and DC pulse test because i want to explore the dc effect.
I wait for ebay some mosfets to make a oscillator, (i don't have a inverter) to test the pulsed DC.
I have curiosity because the effect that i observed when i make basic tests was very interesting.
I could fill 15mf cap with 400v in a single touch of fraction of a second . using the secondary coil and colect in primary coil, or using only  primary coil and without secondary coil connected, the cap fill up in the 2 situations.
I have shure that with a video is more clear what a want to say. need to make the video:)
Basically is like the  video that i make with dc test.
good work and thanks very muck for your donation man
nelsonrochaa
Hi Marsing like i say before in other posts is obvious that Barbosa not reveal the real details of circuit work in  the patent i say this million times!:) Is a maneuver diversion. The patents are based on other people work and Barbosa understand how it works so compile there patents.
Reading the original barbosa patents you could find the numbers of other patents that is used in there patent,
and you ask you: what a fuck? barbosa make a puzzle with a 10 difference patents ? yes!
The effects are similar to ismael project or QEG or akula .Basicly is tesla work .. understanded .
People like akula have the intellect and the material resources so are in the top of run is simple.
In this last barbosa video you can see that i have problems in 1 point of circuit : batteries basically the same problem that ismael have ,  ;). The are much evidences and connections in all this circuits but the principle is all the same EMF , or REACTIVE ENERGY DC or AC and resonance.
Man i am a only curious  man and when i talk i based everytime in testing and observation i read a lot and see ramifications in all circuits and is all the same the only think that change is method to obtain the effect.
Tesla use a spark gap or rotated gap, now we use silicone so what is the difference of resistance when you pulse dc or ac in mosfet or in a spark gap ?
hap it make lot of difference . this is the point.
thanks
nelsonrochaa
Hi greats,
Shure you can do a bigger device and think that is very interesting. The static have much potential, you can see works like lasersaber with free electric  static motor http://laserhacker.com/?p=356.
There are lots of projects like testatika that only us free static energy.
I wll follow you and your tests :)
thanks
Quote from: pavqw on July 17, 2014, 05:44:01 PM
Tommorow I'll try to do some tests with free static frequency energy. If I'll find it is really useable I want to continue in research. I can try to do some bigger devices. It could be very interesting to get power around kW.
From my point of view it is a legal way of getting energy. It is same as you use vapors from a chimney to get some extra heat. It just uses by-product.
What do you think?
nelsonrochaa
People one post more  :o ;D is weekend and im happy :)
I want to put a link of one my new subscription of youtube Gfusion Core.sa
link channel https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3Cw
Man if you listen me you make a great work! proving that all i say about isolate from the conventional principles of electricity if people want to advance is like this man.
I recommend i have great videos about ground system , high frequency energy and other great thinks  .
bye
