Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
pavqw
I am afraid, but rectifier (Gretz) does not helped at all. Voltage is cca 1V DC.
pavqw
I've double checked everything and it seems its OK but it does not work as expected.
Interestingly when wire from a lamp is very close I can get higher voltage but thats all.
It seems when I turn on the device, voltage drops even lower.
nelsonrochaa
make  a photo with the bridge connections to see .
Confirm if the - is grounded and one leg ac bridge ground too.
pavqw
OK, I think it is OK. I have tried both ends of coil with same results too.
It is all grounded as in schematic. Rectifier is just simple full wave bridge.
I guess there should be AC voltage coming from coil/ground.
I am not sure but without neutral from the grid I can't measure any voltage.
GeoFusion
Quote from: nelsonrochaa on July 19, 2014, 07:34:00 AM
People one post more  :o ;D is weekend and im happy :)
I want to put a link of one my new subscription of youtube Gfusion Core.sa
link channel https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3Cw
Man if you listen me you make a great work! proving that all i say about isolate from the conventional principles of electricity if people want to advance is like this man.
I recommend i have great videos about ground system , high frequency energy and other great thinks  .
bye
Hi there nelsonrochaa :)!
Thnk you for your nice comments, yes I have been doing alot of Experimenting for some years now, Have you seen my videos??
Check them out.
I did many experiments with coils and Tesla coils, Royer circuits , and other types of transformers with pulses.
https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3FCw/videos
Btw I have seen that you got a Captor, was very interested to hear about this.
I also did some tests and the results are odd yet surprising.
I did replicate a small captor based on what was provided in this thread, and saw that the Fase (hotwire) works with ground very good and
depending how many grounds you connect to each other like I did, managed to pull 2.0~ amps from ground and voltage around 90V.
I  connected e bulbs of 200 watts ( each 100watts )
I have 127V here on the island.
I managed to put plates in ground, 3 plates  of half a meter wide and half a meter long.
Good output, but the more plates I put the more amps and maintains voltage up. But can't touch the ground haha.
But don't know if the meter can count that what I am using.
I will check your videos out,  Because There must be methods of creating a a Hot wire via e inverter that can pull out amps like how I do with the mains hot wire.
Cheerz :), Hope to share more
