Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
nelsonrochaa
Quote from: pavqw on July 20, 2014, 01:51:07 PM
True, well if it works with static energy, it could be a very normal HV capacitor with very small capacitance.
It drains power from input so unfortunately it is not free energy device :( Or am I wrong?
If there is no load, then there is no input and output amperage. It is very clearly visible on my meter.
how can the circuit drain if in the circuit don't have any connection of the electric phase with the ground ?
Review the circuit because something is wrong.
if you put a circuit open you cant draw current ok ?    and in original circuit the primary coil have one leg  disconnect .
bye
pavqw
Indeed, circuit is open, one leg is not connected and nothing is connected to phase wire to make circuit.
But if you imagine it is really a capacitor, so you can put there some input power and then you can discharge it...
Each capacitor draws some small current until it is charged.
Well, there could be a problem in our house wiring which is quite old. There is PE and N connected together. So it could be a issue.
nelsonrochaa
Good here I leave the last tests ;) but for now is what I can show.
I hope you all take some conclusions of these tests like me.  :o
I'm a little sick  :-[  so not complain to the sniffles ... :)
https://www.youtube.com/watch?v=DaHXLZ6QJss
pavqw
Very nice work!
Tommorow I will try to change Ground from the grid to real Ground and see the difference.
Have you tried to make this device too? Did you measure any consumption between phase input and brass rod?
Thanks
nelsonrochaa
Quote from: pavqw on July 20, 2014, 04:01:15 PM
Very nice work!
Thanks
Hi yes i make a model too, long time ago and works ,  but in my circuit the phase can have any consumption because is open so no current can travel . The phase is only for give de frequence alternations .
Is very easy make a model with parallel units but you need to understand the concept first. see another time in detail the circuit. I another chance of your house have a old ground connection joined with neutral.
bye
