Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Neofln
Like i said to @Enric Toledo in a private email some time ago, u have the wire of closed loop the thicker one, when u put the ground cable around the thicker wire what u get? A primitive capacitor, two metalics surfaces separated by a isolator... Right?
But our friend Ariovaldo got one of these "captor de elétrons da terra" disassembled and nothing special in the connection if i remember right...
Clarence
@ ALL
new to the forum - but I started a the first post and covered everything to present - IMHO the material that was stated to be gravel in the "junk captor" photos appears to be quartz crystal fragments which can be purchased globally. these crystal fragments can give out a piezzo electric effect - they supply the electric spark to fire starters and most cigarette lighters nowadays. since I see a heavy concentration of them poured in the primary toroid area before the resin was added it could be possible to have an extra effect on both the primary and the heavy wire loop in that area. If the other areas of the resin did not have them it would be somewhat of a confirmation.  just a thought.
also why was the captor a " junk captor" ?
LOL Clarence
hanon
Quote from: ILLATIKSI on December 01, 2014, 07:52:04 PM
https://www.youtube.com/watch?v=lUtRFSqj504
This is a video in Spanish that modifies the circuit Barbosa and place a capacitor instead of a ground wire screwed. Very simple to prove.
Cheers..
I
I have found really interesting this modified design with a capacitor instead of the turns done with the ground wire, and connecting the secondary to the primary from the outlet instead in the inlet.
The input is not affected when adding a load. Please watch the video.
Kator01
Hanon,
this design only demonstrates  a mag-amp-effect. The small shorted coil ( 160 t0 200 A) has the effect of saturating the torus-core.
Because of this the reluctance of the big coil is reduced drastically. Without shorting the loop-coil the reluctance of the big primary coil is so high ( 1- 2 Henry) that no active current is flowing but only reactive current. Without load and the small coil shorted the clamp-meter thus shows 0.9 A but what the clamp-meter does not show is the phase-shift between voltage and current. In this phase still only reactive power is oscillating although the inductance of the primary has dropped down ( by saturation) to about 0.1 Henry . Without the capacitor this would come close to a short circuit-situation.
Once you put on a load a respective active power ( and current ) is flowing into the load but still the clamp-meter can not distinguish between active and reactive current. You have a mixture of active and reactive power which does not exceed 115 Watt ( 115 V * 1 A )
There is no overunity effect here and certainly no current drawn from the ground.
I myself have done extensive continuous testing ( more than a year) with this kind of setup ( even without the capacitor) in order to dim loads up to 1 KW. Standard transductor technique dated back to 1930.
This guy has no clue what is going on in his setup
Kator
