Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 28 Guests are viewing this topic.
ElectricPirate
Quote from: Clarence on December 15, 2014, 11:35:16 PM
Hello @ ElectricPirate and All,
Maybe this FULL INFO Kapanadze  item might lift your spirits to keep looking for an answer - I know I am busy as a beaver experimenting on B & L.
whenever I get something worth showing I will show it. Cheers.
Clarence, thanks.
That diagram is not 100% correct as this is only made by Jean Louis Naudin and not by Kapanadze.
This is the real Kapanadze patent and see how small information you can get http://freeenergynews.com/Directory/Electromagnetic/Kapanadze/Kapanadze_Patent_WO_2008_103129_A1.pdf
nelsonrochaa
Quote from: Clarence on December 10, 2014, 12:46:08 PM
Hello @ ALL
Whether this Forum covers the Barbosa and Leal device or not will NOT stop individuals from attempting to replicate their device.
It would seem more appropriate for the members to lead wisely to all potential replicators advising them of harmful methods and practices
as they become apparent to the  gracious experienced and knowledgeable members of this forum.
As a recent member I made it a point to cover all posts from #1 to present and I did observe the many PAST warnings of quite a few valuable
experienced members who were certainly ON POINT!
It is my own personal thought that ANY replication attempts should NOT be tied to a Corporate Commercial Energy Grid system whatsoever!
The Barbosa and Leal  system within their patents EVEN shows that it was intended to be a Battery - Inverter - Captor - Rectificator  closed loop system
independent from other systems entirely!
my own replication effort has been thru a battery powered inverter system from the getgo and will remain that way. all IMHO.
thanks.
Clarence
Clarence
Clarence you have right , the base system work with DC and as i say in other posts the Barbosa patent only show Schematic concept like other inventors did.
People have to see the references in their patents to another inventors to understand how can possible capture electrons,and I can guarantee that it is possible but not like the Barbosa Schematic show.
About to ban this type of topic to be dangerous, seem at all naive to think that there are no serious risks associated with this type of circuits that are shown in this forum.
Everyone certainly are aware of this type of risk.
I could list more than 10 potentially dangerous topics that are currently discussed in this forum.
Thanks
captainkt
@a.king21, I once powered my house for 6 months without neutral, used live to ground.  My earth leakage trip neutral connection burnt out (loose terminal) so I was busy and did not have a new box or time to change it.  Everything worked as normal including the meter readings.
PS. Large farmhouse and granny flat on the side both to a single phase 100 amp meter
PS. PS. I also have a dozen duff inverters
Keith
Zeitmaschine
Quote from: NickZ on December 15, 2014, 08:17:48 PM
Maybe what is needed to avoid problems with the inverters, is to make your own step down transformer, connected too a full bridge rectifier, using the proper diodes, and some caps to filter it.  Or repair and improve the inverters that you already have.
This setup will also create a plasma bolt in the spark gap. The inverter is completely isolated from the high voltage. It was my first setup. So it is a little bit overcomplicated.
ElectricPirate
