Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 27 Guests are viewing this topic.
Clarence
Clarence:
Hello @ All, just a test to see if this actual photo shows up correctly
LOL!
Clarence
HOORAY NOW I know how to send the rest of photos later!!!
Clarence
Clarence:
@ALL
Just another try at another actual photo.
LOL
Clarence
madddann
Hi Clarence!
That's really a nice clean setup.
That green twisted wire at the inverter output is just the inverter's grounding cut off right?
I have no more questions :D
I just wish you luck with your tweaks!
e2matrix
Clarence,  Nice work!   PM sent.   For anyone having issues on the occasional 'too wide' pictures that show up in threads I suggest you get Opera Browser in the older version 12.17 or there abouts.  Install,  click on small triangle in the lower right corner of the browser and when the little menu pops up click "Fit to Width"  - DONE!   It all fits on your screen without making the text smaller and wraps all the text that went off screen so it fits nicely on your page along with the picture being resized down to fit your screen.
A high efficiency inverter may be of help in this setup for tweaking the best out of it.  The Trace / Xantrex I've got is spec'd at 96% efficient and from some results I've seen with it over the years may be even better than that.
On looking at the claimed specs for the AIMS inverter I see it's not bad if it achieves what it claims.   One I looked at (not sure if it's the same used here ) 1000 watt Aims has 95% efficiency at 1/3 load but only 90% at full load.   Not too bad but I'll bet a Trace inverter will be higher.
Clarence
Quote from: madddann on January 11, 2015, 06:14:03 PM
Hi Clarence!
Clarence:
Hello madddann,
You are correct sir -  later I will re-learn haw to safety ground my inverter APART from my replication GROUND GRID SYSTEM.
thanks.
Clarence
