Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
a.king21
Clarence:  Which country do you live in?
Have you done any more tests with your setup, and if so what are the results?
Clarence
Quote from: a.king21 on January 12, 2015, 10:00:19 AM
Hello a.king21,
I live in USA. my larger # 6AWG ground wire hasnt come in yet - probably by Jan 14th, so I
havn't done any more testing yet. maybe more testing by end of this week. rest assured
I will post results. I'm as anxious as everyone else!
thanks to all!
BTW: I have built the single toroid Captor unit and just ran it by batt-invertor-toroid at idle only
and it uses .41amps on the toroid at 34 watts at 116.2 volts from the inverter. on the #4AWG captor
4 ea windings (only one winding passes through the toroid center) the clamp meter amp measure
initially shows 126.9 but after about 5 minutes settles down to 115+ amps. was running a little warm
so I tried something I remembered from my past observations of this past many months!
I knew the "Gravel" Alvarado talked about was actually Quartz crystal fragments and I had obtained some
so I set the built unit in a clear large Glad type container and covered it completely with the quartz
fragments. the temperature on the windings cooled down. I guess it works as a convienient heat sink.
I know that ORGONE followers use the crystals to thwart the presence of unwanted EMF s to help negate them
LOL for now.
Clarence
a.king21
Clarence: Great info and looking forward to your progress. By any chance are you from the Upper Midwest of The USA?
Clarence
Quote from: a.king21 on January 12, 2015, 02:48:46 PM
Hello a.king21,
Clarence:
No - I am an old 77yr white bearded Coon Ass from Iowa, Louisiana! HA HA.
BTW: I just had to cancel my ground wire order - they were out of stock and wouln't have any for 2 to 3 wks so I canceled
and found some Green #6 AWG at PacerGroup Wire Co. out of Florida- should be here by end of week. thats life!
Thanks!
Clarence
tesletic
Hi Clarence, your doing a great job, any link to get schematics and or a part list ? Best regards, Gery  ;)  http://tesletic.com/
