Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
Here's the graph of the Instantaneous Power curve from the spreadsheet data. This is the first thousand samples, equivalent to ten microseconds of data, ten horizontal divisions on the scope screen. (The screen above is from the middle of the 32k samples of data, whereas the graph below is the very front.)
This is the red "Math" trace that would appear on my Link Instruments DSO scope if it could display it.
Note that this is the "AINSLIE METHOD". I am NOT claiming that these are "valid" measurements indicating true power values in the circuit. These are traces which reproduce the effects of stray inductances on the measurements; they are "replications" of the Ainslie-type measurements, only better, due to the Gate Boost circuit which provides sharper and higher-amplitude spikes.  This is the Instantaneous Power trace that averages to -2.153 Watts because of the large amplitude of the spikes.
MarkE
So it is, the forum seems to be doing something to the .zipfile. And I can't edit the original post, the window has expired.
Quite right, I can't get a big .zip file to work properly through the forum's storage and download process.
So try this link for the spreadsheet file:
http://www.mediafire.com/download/5odvhg1rwjgdh2d/Q17PlainBoost04141.ods
and this for the raw data dump from the scope:
http://www.mediafire.com/download/9tocskc3n1ikiig/Q17PlainData_0414_1.zip
Here's a screenshot of the SWeir Q17 "Shifting Paradigms" board with MarkE Gate Boost measurements, running at about the same settings as the "Ainslie Style" measurements taken above:
Note the "average" of the Vcsr (inv) trace is computed by the scope as 0.24 V. Dividing by the 0.25 Ohm value of the CSR we get an average current of 0.96 Amps.
Next, the DMM readings obtained simultaneously with the scopetrace:
