Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
MarkE
Quote from: TinselKoala on January 20, 2014, 10:54:27 AM
The reason for the huge battery banks is obfuscation! According to the Ainslie team, a 12 volt LA or SCLA battery is "fully charged" whenever its open-circuit terminal voltage is 12 volts or more. I know this is hard to believe but I have substantiated it with references many times before. So with a bank of 4 to six nominal "12 volt" silver-calcium LAs with 60 amp-hours rated capacity (as were used for the trials reported in the daft manuscripts), one can run her circuit at high heat values for many trials before seeing depletion in charge using their definitions and instrumentation methodology. Which is just what happened.
Why not use a large capacitor bank? Because it does not obfuscate. Even though the "negative power product" is produced just as with batteries -- in fact, the waveforms are identical -- a capacitor bank discharges at the normally expected rate. Ainslie has used this result to claim that batteries are necessary. Of course.
You may note in the photo below, published by Ainslie in PESN just before the last set of demonstrations.... there is an extra set of red and black cables, terminated by large alligator clips, leading up to behind the oscilloscope, where something is concealed underneath a wadded-up textile, in Ainslie's neat-as-a-pin "laboratory". This "something" is evidently a power supply or battery charger. Odd, isn't it?
The results could be very different if one accidentally left a charger connected and running.
poynt99
Quote from: MarkE on January 20, 2014, 11:10:25 AM
Poynt99, cells are usually rated in Ah.  There are many batteries that are rated in Wh particularly in the rechargeable battery space.
Oki. Did not know that.
Quote from: MarkE on January 20, 2014, 11:31:44 AM
Have you considered the possibility that the DHS, or NSA quickly moved in and neutered available cheese so that what you showed would no longer be possible?
I knew it had to be rats, of one sort or another.
poynt99
I've updated my Burst Oscillator Circuit to get rid of the 5V bias supply, and to simplify the design somewhat.
Many MOSFETs could be used, especially if a high Fo was desired. The PG50 is certainly no the best choice, but I designed around it for the sake of you know who. An IRF840 works just fine, in fact the peak voltage is about double the PG50.
I've posted this over at Rose's forum for Greg if he should be interested in trying it.
MarkE
That's a simple enough solution.
Since he is chasing an energy gain idea I think he should concern himself with either using a switching amplifier, or figuring out how to measure the oscillator's losses fairly accurately.
