Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
Quote from: synchro1 on February 27, 2014, 11:13:10 AM
Mercy!
Mercy?
I give no quarter, nor do I ask for one.
Below see the schematic from one of the AINS-LIE mob's rejected submissions to an IEEE journal, and the block diagram from another. These are AINSLIE'S OWN DIAGRAMS. Note that in both of them, the FG Black lead or the "timer components" negative lead is connected to the BATTERY SIDE of the current-sense "shunt".
As I have said before, the schematics in the daft manuscripts, and Ainslie's claims re the Black FG lead in her present flailings,  are lies, because they ALWAYS used the hookups shown here and above, until the August 11, 2013 demonstration.
Ainslie's stupid references to the FG's outputs as "probe" and "terminal" are part of her confusion. There is a Black or shield/ground lead, and a Red or signal lead, and either of these can be positive or negative voltages; however in _most_ but not all FGs, the Black shield lead is connected to the chassis ground and back to the Earth ground by the line cord of the instrument, and of course to all other instrument grounds and chassis by the hookup to the common circuit probe ground point. This is why the Black lead and the FG itself must be _isolated_ if proper current measurements are to be made. When I reproduce Ainslie's errors, I also use the same hookups she used. When I try to find the ACTUAL currents, I place probes properly and I isolate the F43 FG... easy to do with a simple switch on that unit, no "groundlift adapter" or cutting of power cord pins is necessary with my "garage sale" equipment.
In the run-up to the first 2013 demonstration which finally happened on June 29, she sent some photos to Sterling at  PESN. Here is the shot that shows the Black FG lead connected.... to the Common Circuit Ground, the BATTERY SIDE of the current-sense "shunt".
Always, until the August 11 demo, they used this incorrect connection. IN EVERY PHOTO, EVERY SCHEMATIC, EVERY DIAGRAM _except_ the mendacious daft manuscripts, the Black FG lead is located as you see. And the "correct" location depicted in the daft manuscripts... did not appear until _after_ it was pointed out to her that the connection they actually used enables the FG current to bypass the current-sense "shunt". The schematics in the manuscripts are conscious fabrications, outright lies.
MarkE
Well what's really funny is that during the August 11 demonstration, one can hear Ms. Ainslie objecting when Donovan Martin connected the function generator black lead to the Q1 source side of the current sense resistors.  During the June 29 demonstration when Steve was troubleshooting their problems, Donovan Martin disclosed, and it was visible in the video that the function generator black lead was connected to the circuit common and not the Q1 source side of the current sense resistors as in Paper 1, Fig. 1.  The August 11, video is inconveniently not accessible on her web site at the moment.
Here's a screenshot from the miserable June 29, 2013 demonstration, showing the Black FG lead.... at the common circuit ground, on the battery side of the current-sense "shunt".
So how many different proofs are there that the lying Ainslie ALWAYS used this connection? Count them.
Quote from: MarkE on February 27, 2014, 12:00:45 PM
Yes, suppressing data is another Ainslie hallmark. You won't find her March 2011 video either, except on my channel. I've got the whole August demo video but it's not completely uploaded to my channel, just a couple of excerpts.
But by 23:24 in the August 11 video, the Black FG lead is connected correctly on the transistor side of the csr and Steve is heard to confirm this.
