Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
MarkE
She's really going out of her way to make herself into a complete fool.  Obviously she does not realize it, but she's got herself so tangled up that she actually makes a number of your points for you.  She notes that I asked for the Q1 disconnection test.  And that test performed just as you and I both knew it would:  The oscillations persist unabated without Q1.  Ergo Ms. Ainslie's hypothesis that Q1 carries the oscillating load current during the "Q1 Off" times was falsified by that test.
Then she went on to howl about how this showed exactly what everyone has told her for years:  The current that flows through Q2's source terminal flows through the red lead of the function generator and then out the black lead of the generator.  She specifically measured that during the August 11 demonstration.  Is it a coincidence that in the ten hours it took her to formulate a new response, that the August 11 video became unavailable?
MarkE
Quote from: TinselKoala on February 27, 2014, 12:12:32 PM
Yes, suppressing data is another Ainslie hallmark. You won't find her March 2011 video either, except on my channel. I've got the whole August demo video but it's not completely uploaded to my channel, just a couple of excerpts.
But by 23:24 in the August 11 video, the Black FG lead is connected correctly on the transistor side of the csr and Steve is heard to confirm this.
Steve wrote up a detailed test protocol.  You can see Donovan Martin holding a print copy of it as he worked his way through the demonstration.  Mr. Martin was at least trying.  near the beginning of the demonstration, Mr. Martin shows that they had disconnected the function generator green safety lead from the mains plug, so as to float the generator, thus making it possible to connect the function generator black lead on the Q1 source side of the CSRs while the oscilloscope black lead connections still connected to earth through the oscilloscope frame and green mains safety wire were connected to the circuit common without creating a ground loop.  BTW, I think that lifting the function generator green safety wire was Poynt99's suggestion.
It is pretty comical that Ms. Ainslie accuses you of misrepresentations even as she has now pulled both the June 29, and August 11 demonstration videos.  That makes three demonstrations, and three videos that Ms. Ainslie has pulled.
Let her pull them, it makes no difference to the record. It just shows how LITTLE regard she has for the truth, yet again.
Here's the March 2011 demonstration in full:
http://www.youtube.com/watch?v=P8AIRkWF55k
Here's the June 29, 2013 demonstration, broken down into LITTLE excerpts, with most of the dead air cut out. See what happens, Ainslie, when you relinquish control?
http://www.youtube.com/playlist?list=PLml9VdOeqKa_6b8yMpkYJHIR7F9ah3-1q
I'll upload the full August 11 demonstration a LITTLE later on, I've got something else in the pipeline at the moment.
See below, for the schematic of my next LITTLE demonstration:
You know me... if I see something on YouTube or in a forum post that I don't believe is true, and if I have the tools and equipment and parts handy, I'll build it and test it myself to see if what is claimed is true, or in an attempt to find the claimant's errors so that I can help the claimant out.
What does the Great Scientist Ainslie do? She accuses me of cheating by displaying a stored waveform on a 40 year old analog oscilloscope, she accuses me of not making measurements then a paragraph later she accuses me of making accurate measurements of something other than what is clearly shown hardwired on top of her own schematic. When it would take an actual twelve-year-old child less than half an hour, borrowing Daddys' scope and mosfets, to set up and run the experiment for herself, to SEE FOR HERSELF if what is being presented is true and correct.
Of course that requires some skills, some intelligence and some ability to solve problems.... like which pin of a mosfet is which, and what color "Yellow" is.
Meanwhile, I see that it was a real Little mistake for me to believe that Ainslie could follow _her own schematic_, so I made a much simpler demonstration using the schematic posted above, to show just how the mosfet is actually turning on.  I have asked Ainslie to take a Little 3 question "pop quiz".... maybe the first one she has encountered in all her life...
http://www.youtube.com/watch?v=ilT3LRF0hUA
Hey ROSEMARY AINSLIE:
POP QUIZ 1: WHAT MAKES THE LIGHTBULB LIGHT UP SO VERY BRIGHTLY?   Think about it, if you can.
Hint: The 9v battery and the 12v battery are placed in SERIES when the mosfet is ON.
POP QUIZ 2: WHAT IS TURNING THE MOSFET ON?
Hint: what is the _difference_ in voltage between the Gate and the Source?
POP QUIZ 3: What happens when you REPLACE THE 9V BATTERY WITH A FUNCTION GENERATOR?
I know the answer. By this time, so should YOU.... but I'll bet you don't.
Bonus Question: What happens if you replace the 9v battery with a Function Generator, AND you replace the light bulb with your normal "element resistor"?
The August 11 demonstration video will be here when it is done uploading, probably in an hour or so. I have a really slow upload connection.
http://youtu.be/ld-LTPxmoQA
