Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
Well, this may be some kind of record-setting run of silence. Three, or is it four days now, of peace and quiet, of freedom from insults and mendacities.
If "they" are actually performing any honest testing, they will by now be very frustrated to find that a "negative power product" sitting in boxed numbers on an oscilloscope screen does NOT translate into battery charging, excess heat in a load, or even a lengthening of rundown times. They will have been amazed once again to find that the Figure 3 screen, when honestly obtained, does not produce high heat in the load because the Q1 isn't turning on. They -- some of "them" anyway -- may actually look at my recent videos and find nothing that they can rationally object to.
If there are even any of "them" left, at all, that is.
MarkE
Quote from: TinselKoala on March 28, 2014, 09:32:18 AM
Maybe the Ms. Ainslie and her collaborators are learning something.  It's not very likely, but it is possible.
You have proven that Paper 1, Figure 3 cannot be obtained using a circuit configured as shown in Paper 1 Figure 1 with properly functioning components.  As demonstrated June 29, 2013, it can be easily obtained by connecting the Channel 1 oscilloscope probe to the wrong side of the current sense resistors.  And as you have shown it can be obtained with an open Q1.  Given the location of their function generator black lead, the voltage indicated on the oscilloscope Channel 1 during Q2 oscillation periods was not from the function generator, as the function generator was connected around the even the erroneously unmonitored current sense resistor.
MarkE
How does one generate the same amount of heat powering a resistor of value R directly from a battery of some voltage V, and another resistor of the same value R from the same battery voltage V through a PWM, especially if the PWM duty-cycle is in the range of 3.7%?
Well.... if one is Rosemary Ainslie, it's easy. One just lies about it.
poynt99
I suspect the value of the control R will be increased so that the temperature rise above ambient is the same in both cases.
So in case of the experiment, it might involve short pulses of high current, while the control will be a lower, steady-state current.
Would this be a truly fair comparison? Considering the well-known "vagaries" of battery discharge rates and capacity, no in my opinion.
